no change
Do you have full fuel pressure, if the pressure isn't high enough it will not fire. Install a guage off the rail. The O2 sensor, from what I am told is disabled by the computer for the first few minutes till it gets heated up.
Other than that, I have no suggestions, but it sounds like you are having fun.
Dean
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
I think it's this story...Fordman wrote:what is the back story? i didn't see it.
http://fordtruk.com/forums/viewtopic.php?p=87366
61 Merc wrote:Do you have full fuel pressure, if the pressure isn't high enough it will not fire. Install a guage off the rail. The O2 sensor, from what I am told is disabled by the computer for the first few minutes till it gets heated up.
Dean
not sure if it has full pressure but it squerts gas out the bleader on the fuel rail 2-3 inches high i can hear the fuel pump running. i took off the fuel line at the filter and ran it in a jug and turned the key over for a few sec. and it pumped a few ounces of fuel in the jug
there a guy supost to come tomorrow and read/check the codes
yeah its been lots of fun so far..lol
It could possibly be the idle air bypass motor failing. If it sticks in an open position it will cause you to have a vacuum leak. The idle air bypass can fail due to mechanical or electrical problems, and sometimes because of a chunk of loose carbon stuck in it. It's about a 50-60 dollar part.
61 f100 shortbed unibody
ridgerunner
no change
i had a fuel regulator go bad that acted the same way
where do i find the idle air bypass motor & how can i check it?deviant1 wrote:It could possibly be the idle air bypass motor failing. If it sticks in an open position it will cause you to have a vacuum leak. The idle air bypass can fail due to mechanical or electrical problems, and sometimes because of a chunk of loose carbon stuck in it. It's about a 50-60 dollar part.
Re: no change
where is the fuel regulator and how do i check it?ridgerunner wrote:i had a fuel regulator go bad that acted the same way
- ezernut9mm
check these guys out: http://www.tccoa.com/
they can be a pretty helpful bunch. thunderbird and cougar club of america
The Idle Air Control Valve will be just back from the throttle body on the intake, should have 2 small bolts and a wire plug in it.
The Fuel Pressure Regulator will be on the fuel rail and may have a vacuum line running into it.
Look the parts up on Autozones site and match them with the pics.
