Radiator
ProStreet66
Radiator
I have a 64 F100 with a flame breathing,tire burning,wheeliepopping(If I can get the tires to hook up)460 going in. I am wondering about a radiator to cool it. This truck will be street driving most of the time. I was wondering if a 70's style radiator would fit. Anybody have any ideas. Thanks
- FORDMANLCRACKEL
It will work, just a little mod. is all it takes.
Lonnie
Lonnie
The most rewarding job i ever had was being a dad.
1988 Ranger Build http://s275.photobucket.com/albums/jj31 ... %20RANGER/
ProStreet66
radiator
Ok,Thanks for the info. I will look for one.
- Uncle Skip
Merle.
As nice as your truck is, you need to look for a custom Aluminum radiator. There are several manufacturers available if you GOOGLE "aluminum radiator".
E-250 vans have big radiators too, but if I were you I'd go for the aluminum job.
Just my dos centavos worth.
U@ss
U@ss
Aluminum is the way to go
http://store.cal-mustang.com/cm_able/sh ... 19&CM_SA=1
I just put one of these in our Classic '65 2+2 Mustang. It dramatically lowered the running temps.
Good Luck!
Good Luck!
Born2
My truck has a radiator that is a fair bit bigger than the stock one, I didn't do the job, but it looked easy, they just used lots of washers to shim it. You probably allready thought of this, but who knows, this might help someone.
________________________________six-two
(edit: now that i posted I realize that your truck is way too nice to shim the radiator, but hey whatever.)[/u]
Radiator
Hi Merle,
The radiator in the XL is out of a "63" F-800, I think that all of the big trucks had the same radiator. You will have to take it to a radiator shop to shorten the core about 6" to get it into the pick up core support, otherwise, its a boltin.
Bill.
Bill.
XL
- Johnny Canuck
unibodyboy
radiator
I have a custom aluminum dual crossflow that was made to fit a 61-64, however the inlet and outlet port's were switched around, opposite of those for my Yblock so I had to order another. Don't know which sides the 460 are on, but if interested it is sweet...
Greater love has no man than this, that a man lay down his life for his friends. John 15.13
