Tranny id
61ford
Tranny id
Post by 61ford »
Does anyone know where i can find a decoder to see what type of tranny ive got?I was gonna put a 5 speed behind my 351 but ive got this one and if it works ill just use it.i think it accepts two different bolt patterns and ive got these casting numbers c8ar 7008-C
Ryan
61 Ford f100 Unibody short bed
351w/Aod
61ford
Post by 61ford »
i believe ive found out its a toploader 3 speed.anyone know if 4 speed bellhousing will interchange with the 3 speed.sounds like it will work with the 351w i was gonna put it on ebay if it didnt
Ryan
351w/Aod
adrianspeeder
Post by adrianspeeder »
Which 4 speed are you gonna use?
Adrianspeeder
61ford
Post by 61ford »
no its not a 4 speed its a 3 speed toploader has 9 bolts instead of the i think 10 for 4 but im trying to figure out if what kind of bellhousing i can use
Ryan
351w/Aod
Hawkrod
Re: Tranny id
Post by Hawkrod »
61ford wrote:Does anyone know where i can find a decoder to see what type of tranny ive got?I was gonna put a 5 speed behind my 351 but ive got this one and if it works ill just use it.i think it accepts two different bolt patterns and ive got these casting numbers c8ar 7008-C
That number can't ID a trans beyond the fact that it is a 68 and newer trans. The number you posted is just the cating number for the case and has nothing to do with what it actually was machined for. On the side of the trans case is small metal tag held on with a rivet. The numbers off of that will ID the trans. The dual bolt pattern cases will bolt to almost any Ford bellhousing if you use the right front bearing support (there are two different sizes). Hawkrod
61ford
Post by 61ford »
thanks hawkrod ill dig it out and look for the tag.ill post tomorrow what tag says
Ryan
351w/Aod
