Mono front leaf springs
ProStreet66
Has anybody used mono front leaf springs in there trucks? I have a 64 F-100 and would like to try them but dont know if its a good idea. thanks for any info.
Thanks, yes it is the green truck. Just mono leafs on the front, and not the reversed eye (if I remember correctly).
I took out every other leaf out of the rear spring packs, and it softened the ride up (still 5 leaves) and then made some brackets on the rear end housing and the crossmember behind the rear axle and mounted some air springs to be able to adjust the ride some when the rear is loaded with luggage and car show tent, chairs and coolers, etc. i have an onboard compressor and small tank mounted on the outside frame rail on the passenger side just behind the door. I have driven the truck now to several shows, on 5 to 6 hour trips altogether about 20K miles since putting her back on the road, and I am very happy with the ride, but soon will put on some anti-sway bars.
Chop
Chop
ProStreet66
- mikecarson
ROFL!!
We went thru that in Chat last night, buncha confusion!
Mike C
64 CC, Crown Vic project
62 CC
67short 94 F150, 433W
62 CC
- Truckfarmer
Cool guys. Thanks Truckfarmer for the comparo. Here is the link that didn't turn out on your post:
http://fordtruk.com/forums/album_showpa ... user_id=12
My Slick is rustier than your Slick!
