Heat riser
Heat riser
Where can I get a new heat riser or at least a bimetal for my 223?
i have seen some on e-bay from time to time.the 292 uses the same one.not sure about other engines but as long as the size of the hole and bolt pattern match you can use it.
the little flapper valve in the exhaust manifold.the bi-metal is the curled spring.the butterfly stays closed until the engine warms up,heating the spring which opens it.
- ezernut9mm
