power assist to single I beam
merc uni
Post by merc uni »
I have just finished puting 70 mustang power assist steering on my 62 Unibody .I had a machinist friend make a new drag link to accept the control valve and made a bracket bolted to the axle/spring U bolt to hold the fixed end of the ram. The other end is attatched to the tie rod.The pump came from a 78 or 79 F150. All rather generic Ford stuff.The valve and ram are in "as they came off the car"condition,but don't leak .
My problem is that it seems easier to turn the wheels right than left while the truck is stationary. There is also some chattering/steering wheel shake when turning the wheel right quickly.I have not driven down the road yet and am hoping some Ford guy will have some ideas. Thanks.
REDLTD
Post by REDLTD »
Hi. I'm a lurker who recently signed up. I'm a new guy. My oldest son has a slick, and my younger son has a '67 mustang with power steering we just re-built. I can see that system working well on a straight axle slick.
I think you have air in the system. Try lifting the front wheels, and turning the steering wheel lock to lock a few times. I think there's even a Ford standard proceedure for this. I'd like to know how this setup works out after you get the bugs worked out.
Good luck. Bert
Greg D
Post by Greg D »
I have thought of using this setup myself, found on lots of Fords so should be easy to find.
