66 F-100 Frame vin numbers
ajbanks8844
Post by ajbanks8844 »
I would like to say HI to every one here as I'm new to the site.
I live in Las Vegas now having moved here a year ago from Mich. I need to register my truck here and they tell me this is a frame state (they need to see the vin number on the frame a valid Mich. title is no good) the problem is the numbers on the front frame are no longer there as I clipped it. are they any were else on it.
Thanks for your help!!!!!
frank66
Post by frank66 »
Welcome.
What if you stamped the Vin # on to another part of the frame?
the vin is stamped in 2 places on the pssenger side frame, the first one you removed is about 1 foot rear of the core support, the other is directly under the passenger floor. cant see it with cab on.
the vin is stamped in 2 places on the pssenger side frame, the first one you removed is about 1 foot rear of the core support, the other is directly under the passenger floor. cant see it with cab on.(unless you have a 4x4 or f350 with the battery under the floor)
Slick Fan
Re: 66 F-100 Frame vin numbers
Post by Slick Fan »
ajbanks8844 wrote:...and they tell me this is a frame state (they need to see the vin number on the frame a valid Mich. title is no good)
Geez, how lame is that? Dumb rules. :roll:
banjopicker66
Post by banjopicker66 »
Dumb perhaps, but more and more states are going to it in attempts to reduce theft and fraud.
A good reason to consider carefully a frame swap.
Do the paperwork, and make sure you can get and keep all the titles, or go to the trouble of upgrading your Slick rather than swapping bodies.
Also be careful when buying a Slick, to compare the frame VIN to the title.
Bills 66
Post by Bills 66 »
I was able to see mine using a mirror after carefully cleaning.
Bill
Garbz
Post by Garbz »
Yes more and more states are doing a level one or two vin inspection.. Thanks to E bay and bad paperwork.
Hopefully the vin on the remainder of the frame will match the title or they may impound it at the inspection...
Garbz
66fordtrucknut
Post by 66fordtrucknut »
Maybe for once I'm glad I live in Md. No inspection at all on historic vehicles, just go get tags.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
64 litl un
Post by 64 litl un »
One thing you can do is after that area is clean the area and get some Silly Putty and mash it over the VIN. This will inprint it on the putty.
I would record the number at home, practice imprinting the number so I could do it quicky if the inspector had to wittness.
I can drive it home with one headlight.
ajbanks8844
66 F-100 frame vin
I would like to thank every one for the info on the locations of the vin numbers on my truck. When the weekend get here (and nun to soon) I will see if they are there, when I did the frame it was cleaned and painted.
thanks again.
NYf-100
Post by NYf-100 »
My '65 had very little paint on it and a lot of rust. When I finished wire brushing and sanding the frame with a DA, I still could easily see the factory stampings. My suspicion is you should be able to make them out, especially the stamping just ahead of the rear cab mount on the top of the passenger rail.
Bill
