speedomter cable
63 wrongbed
speedomter cable
Post by 63 wrongbed »
I put in a 63 fordomatic transmission in my 63 F100, it had a 3 on the tree I used the original cable but it is reading about 15 mph slower. I was wondering what tooth gear I need to get for it read correctly, any help much appreciated
longcabjohn
Re: speedomter cable
Post by longcabjohn »
use the gear from the 3 speed, gears match rear end not trans
Johnny
63 wrongbed
I used the speedometer drive gear from the 3 speed, it reads 15 mph slower bat 40 mph
If it was reading wrong before and seems to operate normally it probably had the 4.56 axle originally. Do you know the current axle ratio?
