What Year Of Heater Core Is Close To A Slick?
I read somewhere a different heatercore would fit the Slick60's pickups. I have a 1965 2wd F-250 with the slopped floor, not the step. Would like to get one likely to be in stock on a Sunday.
Thank's
EDIT: Blower motor is in the cab.
longcabjohn
Re: What Year Of Heater Core Is Close To A Slick?
Post by longcabjohn »
Thru 72 without factory air is the same except the tubes are longer. If you have a radiator shop the can recore yours, I used a core from a later LTD that was within 1/4 inch
and put my end with outlets on it and put it in Skyliner.
Johnny
Thank's, I'll look into it Monday. My Spectra core was only in for 2 or so years till it started leaking. Of course this happens just before we leave for a 9 hour trip. Seems someone had one from a latter year that was close enough to work in a jam.
greentruck
Post by greentruck »
may be to late ,but a 66-77 bronco heater core should work
66 f100 4x4 ,64 f100 4x4 ,65 f100 2wd, 76 bronco, 74 bronco, 68 bronco, 69 mustang mach 1,68 torino gt,42 ford gpw
greentruck wrote:may be to late ,but a 66-77 bronco heater core should work
I'll look at that option when I get back. Thank's
