I purchased new tires and wheels.
Tires are BF Goodrich MT 265/75 R 16 E on wheel vinets 16 x 8 wheels.
Previous tires where 235/85 R 16 E Michelin tires on Ford OE 16 x 7 wheels.
At speeds above 60 truck has considerable rear end sway.
Does anyone else have this issue with wider mid tires on aftermarket wheels?
Rear end sway
- Blackwaterforge
Rear end sway
If it cain't be fixed with a sledge hammer it must be an electrical problem!
Re: Rear end sway
Reversed for me on a 94 and 96 F-250. I run Cooper 235/85R16 E on the 65. I never cared for 235/85R16 Michelin or Uniroyal Load Range E due to rear sway. Even with 80 psi the side walls gave too much. Worse with a trailer. If you have Load Range D in the 265/75R16 the max psi is 65. The tire man may have only put 50 psi. With your (7,500lb ?) truck that could be the issue. Dad ran 265/75R16 E on his lwb 4 door simgle rear wheel C30 with a tool box bed. I do not remember any sway with it.
- 6166 Junkyard Dog
Re: Rear end sway
if the tires are real aggressive in the tread then it will sway, we put some on our wrecker and had to take them off real fast due to real aggressive tire sway and go with less of mud gripping and more to hwy. tread
Dakota,,, RIP will never be the same looking for 61-66 trucks again ,,
Kathy
Now Cooper will try his best
- Blackwaterforge
Re: Rear end sway
Thanks guys!
