223 single barrel carb to dbl barrel carb
golfcruiser
Post by golfcruiser »
Where can I get a 2bbl carb setup for the 223 6 cyl. I have a 1964 f100 stepside. Want to try and find a 2bbl carb and new upgraded manifold.......
If you all have done this or can help me find some places that sell this, please let me know.......My carb is pretty much toast, so figured why not go ahead and upgrade.
Thanks
Jaybo
wndsofchng06
Re: 223 single barrel carb to dbl barrel carb
Post by wndsofchng06 »
Clifford's for some big $$
MPH
1963 F100
Durham, NC
Gritsngumbo
Post by Gritsngumbo »
Or get an adapter to fit a 2 bbl to your old manifold.
BIG RED: 62 F100 Long Uni
BIG “UN": 63 F250 Long Flare
golfcruiser
where can I get a 2bbl adapter from......Ebay, Local Auto Parts, Special Order online somewhere?.....thanks for the help in advance
Gritsngumbo
Here's one that looks like it would work.
http://www.amazon.com/Trans-Dapt-Perfor ... 2b3411daee
If not just google.
golfcruiser
ok....I have found a 1bbl to a 2bbl adapter, are there any recommendations on carbs themselves......is there a particular carb I should be looking for or can I just go on Holley or Weber, etc.....and find a generic carb?
bobenhotep
Post by bobenhotep »
I used a trans dapt 2025 with a holley 94 2bbl. The holley will have the spark valve if you are running one for an early y block.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
wndsofchng06
What is the advantage of a 2bbl carb on an adapter?
MPH
1963 F100
Durham, NC
carbs are not cheap anymore
might be able to find a deal on the clifford stuff, i did both times i used them
much improvement with a holley 2v on both the 223 and 300
one of the easier mods you can to to a 6 to help it out
as for the adapter i think you will gain some but not as much as with the clifford or offenhauser intake flow.
i liked the sound of the 6 with the headers too
Ice,
I am currently doing this on my sons 223 some issues with carb which one did you use? and what mufflers?
I agree on deals being out there but headers are harder to find.
had a holley first then switched to the autolite both were slick vintage carbs, i still have the holley, soon as i ever get time im going to get a kit and put that back on my 292 as the current c3te autolite has a few issues
had oval glasspacks on the wifes 66, should have put them back further as was a bit loud under the cab with turnouts in front of the rear tires
the first clifford i got intake and headers from a good friend for a c-note , not a deal to be found like that very often.
the other one i bought from a member, ended up selling it to another, not sure who has that now but i think i paid $175 for that intake
golfcruiser
thanks for all the advice, still havent gotten carb yet, checking around
64 litl un
Post by 64 litl un »
Warning......
The 223 was equipped with a Loadamatic distributor and carburetor. The Loadamatic dizzy was 100% vacuum advance requiring the matching 1bbl carburetor to work the vacuum advance. These components work together. Changing out the carburetor means changing the distributor to a conventional mechanical/vacuum type as well. A Petronics electronic conversion makes no difference as the advance has nothing to due with the type of ignition.
It might even run OK with just a carb change but it will never run right unless you change the dizzy as well.
I can drive it home with one headlight.
