Could someone explain how to tell (without having the car as a reference) if a CV front end was removed from P71 Police Interceptor or standard car?
I have the opportunity to purchase the front end shown below for $200, but I'm not sure if it is from the correct year range and if it is compatible with my 64 F100.
I think the only difference between civilian and cop cv suspension was the rate on the coil springs. Don't take this as bible verse, it just what I remember from somewhere. You might see if you can get a part number off them and run it. I think fords had paper tags on there springs, you might be SOL since they tend to disintegrate over time.
I agree with 65styleside on the springs..
Those sections of frame rail being included is a plus... you'll want to cut out and reuse the bolt sleeves as they are threaded.
