65 core support
Posted: March 22, 2014, 5:52 pm
by 62bigwindow
Can a 65-66 core support be modified to work on a 61?Had anther member point out that the support I have repaired and painted was for a 65 bang.gif .We surmised I could probably remove the angle brackets that the inner fenders bolt on to and drill holes for the 61-64 style.Is that the only mod needed or should I look for a different one?
Re: 65 core support
Posted: March 22, 2014, 7:30 pm
by Toyz
Shouldn't be a problem. Radiator mounting may require a little work depending on your engine.
Re: 65 core support
Posted: March 23, 2014, 10:35 am
by foodstick
If you are capable of taking apart a trucks rusted front end with broken and rusted clips...you can make the radiator support work ! I have even used the radiator that goes with the different support instead of the original radiator ...
Re: 65 core support
Posted: March 23, 2014, 1:17 pm
by 62bigwindow
Thanks.I just wanted to be sure before I tore into it.I am planning on using a Champion radiator so I will have to mod mounts anyway.
Re: 65 core support
Posted: March 23, 2014, 6:36 pm
by Gritsngumbo
AIUI the 65 core supports are in short supply (one year only). You could probably sell that one at a premium (if it's in good shape) and buy one that fits your truck.
Re: 65 core support
Posted: March 25, 2014, 8:44 pm
by 62bigwindow
It is in excellent shape.Had all the rust fixed and sandblasted and painted.Its ready to bolt on.I would much rather find the correct year and pass this on to someone who needs it than to modify it to fit my truck.
Re: 65 core support
Posted: March 29, 2014, 10:26 pm
by 34rdztr
i have some 64 core supports but will have to ck and make sure of condition if you are interested. pm me if interested
