Bench Seat Upholstery
William-in-St George
Post by William-in-St George »
http://www.ebay.com/itm/67-68-69-70-71- ... 9b&vxp=mtr Anyone used this or similar to re-upholster a bench seat? I also thought I'd buy some high density foam and carve it up to fit. I still have the old biscuit but it stinks and is hard and crumbly. I could still use it as a pattern. Any experience or better ideas? Truck is Rangoon red. Thanks!
William-in-St. George
rbeck204
Re: Bench Seat Upholstery
Post by rbeck204 »
I have used seat covers from Distinctive Industries (they are sold through a large network of dealers). They are precut and fit exceptionally well. They are a FORD licensed manufacturer. The covers also INCLUDE the Ford embossed logo in the upper center of the seat. I believe they are about $240 retail. I replaced the foam from local sources.
I have a new in the box, embossed seat cover in Dove Gray that is left over from a project because I changed the color of the interior.
It is 4 weeks old and I will sell it for $200 plus shipping.
If interested let me know,
61 T Bird Convertible
1953 Ford Customline 2 door
tomsrod
Post by tomsrod »
Look up SMS Upholstery in Oregon. They can send you original style fabric with the gear and lightning bolt embossed.
Pat
Gritsngumbo
Post by Gritsngumbo »
The foam is readily available also.
BIG RED: 62 F100 Long Uni
BIG “UN": 63 F250 Long Flare
Thanks Guy's. I need of red/red cover. I see Sumit sells this stuff. I want a simple install it yourself and drive on. This truck is a DD. Thanks for the assist.
tomsrod wrote:Look up SMS Upholstery in Oregon. They can send you original style fabric with the gear and lightning bolt embossed.
Pat
Did the V8 trucks get the lighting bolt also?
tomsrod
Post by tomsrod »
Mine is s a V8 and has one, but it is also a Custom Cab. I don't know if the embossed gear and lightning bolt was specific to Custom Cabs.
F7BIGJOB
Location: West Greenwich, Rhode Island & Providence Plantations
Post by F7BIGJOB »
I think the only one to not have any logo was the black commercial seat. :2cents:
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
1green66
Post by 1green66 »
I have a standard cab '66 short bed six cylinder that has the green interior. The seat cover is original with no embossing on the back. It is original and still had a clear seat cover on it when I got the truck. The only other one that I have seen with the same pattern was a black seat in a 4x4 '66 junkyard truck. It is a basket weave pattern on the entire seat bottom and about 2/3 of the back. The top 1/3 of the back is a regular grain pattern.
Rusty 63
Post by Rusty 63 »
rbeck204 do you have a link to an image of those Distinctive Industries covers? Or a good source?
1green66 wrote:I have a standard cab '66 short bed six cylinder that has the green interior. The seat cover is original with no embossing on the back. It is original and still had a clear seat cover on it when I got the truck. The only other one that I have seen with the same pattern was a black seat in a 4x4 '66 junkyard truck. It is a basket weave pattern on the entire seat bottom and about 2/3 of the back. The top 1/3 of the back is a regular grain pattern.
See F7BIGJOB's post on seat. If that is correct our trucks may have been ordered with a cloth commercial seat. My F250 seat is same as yours.
rbeck204
Post by rbeck204 »
Go to distinctive industries web site and they have a list of dealers.
I have purchased 6 from them and they are a great product.
F7BIGJOB
Post by F7BIGJOB »
Commercial BLACK = vinyl :2cents:
F7BIGJOB
-Steve
I checked out Distinctive Industries and the info I found talked about"original fabric". I Just want a new red seat upholstery cover that I can install myself out of the box. Distinctive didn't show that on their web site unless I am missing something. MAC's has seat covers listed but no pictures. SMS is similar to Distinctive in that they sell fabric and you hire someone to put it all together. The cover I removed was not the original Ford cover but a nice aftermarket cover that was worn out and not the correct color. That cover did not use hog rings rather plastic sleeves that clipped over the seat frame. There were a total of two hog rings in the entire install. I don't have hog ring pliers so doing two the hard way would not be an issue. At 250 or so bucks I'd hate to buy something that will require an upholstery shop to install. Thanks!
1green66
Post by 1green66 »
Mine is all vinyl and green. I was a little off on the back design...two inset basketweave inserts. I haven't ever seen another seat like this other than black ones.
11466
Saw that the first time. Could be more than one style.
Thanks everyone. I ordered a red upholstery cover from NPD. Fits 73-79 Ranger XLT PN# F USRX-73VV-B cost 250.00 or so. I'll post back when I get it.
Got the upholstery from NPD today. Very nice and will be more than adequate for my DD. I ordered some weldwood glue and a piece of 1/2 inch thick high density foam. I plan to add this bit of extra foam because I will not pay nearly $300.00 for an original replacement. Two of the back supports were broken so I welded in a couple of 1 inch strips. The lower spring wire was broken so I got some 9 gauge galvanized wire and replaced that. I also added two extra springs outboard. Likely didn't need these but I'm always trying to improve on stuff. I'll post back when I finish. The NPD cover looks really nice, all vinyl. I wish the seat area was fabric. Gets hot as hell here in the desert.
foodstick
Post by foodstick »
I used to see a upholstery guy glue foam into damaged seat cushions, and then carve them to shape with an electric carving knife.
And I THINK there is supposed to be a layer of burlap? over the foam..
foodstick wrote:I used to see a upholstery guy glue foam into damaged seat cushions, and then carve them to shape with an electric carving knife.
Thanks for that tip.
