Been laying out the wires for my chop and sorting out what I do not need right now. I do not want to cut and get rid of what I do not want/need right now but I do not want to just roll them up and leave them under the dash either so my solution is to cut them and put plugs on them so it is clean under the dash and save the extra wires so if I ever need them I will just have to plug them into the harness and run them where they need to go...........Kid
no gauge auction at SS next Year
extra wires in a new harness
There are some Days I should not be let to go into the public without adult supervision
Re: extra wires in a new harness
Good plan!
"One Test Result is Worth One Thousand Expert Opinions" - Werner von Braun
guess I should run the ones through the firewall bulkhead and then put the plugs on the ones needed outside the cab like the elec fuel pump and a few other extras
Gritsngumbo
Be sure to mark/tag them and then give a list describing which goes where to Robin. You're fairly young now, but memory fades you know.
BIG RED: 62 F100 Long Uni
BIG “UN": 63 F250 Long Flare
rickairmedic
Kid I like this idea as I will be trimming down the Crown Vic harness quite a bit buuuuuuuuuut there may be things from it I want to add back in the future power windows and door locks as a couple of examples
Rick
Rick
