Anybody done a C.V. swap with big wheels on a 65?
Posted: July 6, 2013, 1:35 pm
by milldinaire
I need to know if I should stay in the relative area of my center line or go back a tad? Kids are asleep so it is a real pain to pull the strut to check articulation at different heights. Also I'm running air bags up front, curious if anyone has done this and is there any kind of turning radius down low?
Thanks in advance.
Jeremiah
P.S. 205-215/30R22
Re: Anybody done a C.V. swap with big wheels on a 65?
Posted: July 6, 2013, 1:45 pm
by milldinaire
Kids are up . Power tool time.... muuuuuah muaaahh
Posted: July 7, 2013, 1:06 am
by Crazy blu
Casey the painter for gas monkey garage is running 20s on cv set up, well was he got sponsored by ridetech so now has that! I'm speaking of the Frankenstein truck they built. Ill add pics if you want. I know a guy with a d100 running 22s as well cv set up as well.
Posted: July 7, 2013, 1:07 am
by Crazy blu
It's run a 265/35 personally it's a 29" tire which is perfect for dropped trucks. I actually have two brand new nitto 420s for sale if you need great tires half the price of discount tire.
Posted: July 7, 2013, 10:35 am
by milldinaire
I was measuring for 29". It seemed like I was running into interference down low. So I was thinking 28". That also would help with fitment when I lay the bed on the ground. 29" goes to thetop of bed and wheel wells will be above bed. That is why I was leaning towards 30 series tires.
Nitto tires are my favorite tires Crazy. That is the brand I plan on running, they are some hook monsters.
Thanks for the feedback crazy blue.
Posted: July 7, 2013, 1:54 pm
by Crazy blu
I see your bagged now my bad!
Posted: July 7, 2013, 5:00 pm
by milldinaire
It's all goooooood bud. Thanks for the info. Every bit helps and I wish I could buy those tires off you man.
Posted: July 8, 2013, 9:52 pm
by lowdown65
I have a 65 with cv front-end bagged. I was running 22" wheels with rubber bands no problem but I took out fender wells. Now I'm running 18" wheels with a bigger tire. Still no problems. I'll have to look on mine tomorrow for the tire size.
Posted: July 9, 2013, 7:52 pm
by milldinaire
Lowdown I am wondering if you changed position of your suspension to clear wheels for turning or if you stayed in the stock centerline location? Also hind sight being 20/20 was there anything you would have done different? Thanks in advance.
Posted: July 9, 2013, 10:33 pm
by lowdown65
I stayed in the stock center location. I'm having no issues rubbing. Would I do things different? You know, its a cheap way to go to independent suspension, easy to install and handles awesome, but cambers bad when bagging. I would run it again on another slick but probably won't bag it.
Posted: July 12, 2013, 6:13 pm
by milldinaire
Lowdown, thanks for your help. I'm gonna go ahead this weekend and mout this up. Once again thanks for your input.
