TIPS ON PUMPING GAS
Cletus Earl
TIPS ON PUMPING GAS
Post by Cletus Earl »
TIPS ON PUMPING GAS
I don't know what you guys are paying for gasoline.... but here in California we are paying up to $3.75 to $4.10 per gallon. My line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every gallon:
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we deliver about 4 million gallons in a 24-hour period thru the pipeline.. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode If you look you will see that the trigger has three (3) stages: low, middle, and high. You should be pumping on low mode, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL. The reason for this is the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up; most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom.
Life is simpler when you plow around the stumps
Re: TIPS ON PUMPING GAS
Cletus Earl wrote:Remember that all service stations have their storage tanks buried below ground
unless you live in Alaska where they have above ground tanks.
big deal up there about the temp and the amount of gas ,you get more in the winter than the summer.politicians keep saying they want proper calibration but it never happens.
BiffWilley
Post by BiffWilley »
I had no idea about all of this! THanks for the tips! Much appreciated!
Cheers,
Biff
LM14
Post by LM14 »
This has been passed around for years. While not totally false, it is only marginally true.
http://www.snopes.com/inboxer/household/gastips.asp
I'll just buy it when i need it and pump it fast.
SPark
