Hood Hinges
GJ1963
Hood Hinges
Post by GJ1963 »
I have read through several threads here regarding hinges and tried the suggestions. Wondering if my hinges are OK. Putting the hood down is a multi step process. Go from side to side and push each side down, finally get it to latch up front and then go back and forth to each side pushing down. Then it still sits up at least an inch at the back, and once driving it rises some more. Are these hinges ok or should I be looking for new? It looks like an alignment pin in the middle is broken? Been watching the junkyard, but only two have gone through since I have had this truck, and the hinges were gone before I could get them.
Bill W
Re: Hood Hinges
Post by Bill W »
Your hinges are toast.... they do sell reproductions, but from what i understand originals are better (if you can find good ones)
MadMaxetc
Re: Hood Hinges
Post by MadMaxetc »
Sorry buddy, those are toast.
You might be able to bend them back, but it would be a lot of work.
My Build Thread
donald luster
Re: Hood Hinges
Post by donald luster »
There are people that rebuild the original. Check in Hemmings news magazine for people that do that. If yours are bent they may not be able to repair them. If my memory serves me correct there are some members on other ford sites that repair them with new pins etc
Re: Hood Hinges
Where are you located?
Maybe someone has a set near you
Just sayin some folks on here have been known to help
dbrady
Re: Hood Hinges
Post by dbrady »
I have an extra set and you are welcome to them. Am in Charlotte.
Darren
2010 F150
1967 Mustang Coupe
1966 F100
GJ1963
Re: Hood Hinges
Post by GJ1963 »
Thank you all for the responses. I figured they were bad but wanted to make sure I wasn't doing something wrong with adjustment. This forum is great :P
DukeRoche
Re: Hood Hinges
Post by DukeRoche »
I have an extra set to but am in Pennsylvania. Not sure if someone is closer.
The Green Machine
GO ARMY, BEAT NAVY!
therealjoeshmoe
Re: Hood Hinges
Post by therealjoeshmoe »
DUDE JUST POP THE SPRINGS OFF AND YOU CAN GET SOME EXTRA LIFE OUTTA THOSE... YOU WILL HAVE TO USE A PROP ROD BUT JUST TRY IT I BET IT WILL WORK PERFECTLY AND SIT DOWN LIKE ITS SUPPOSE TO WITH OUT ANY WALKING BACK AND FORTH... THATS WHAT I DID TO MINE 10 YEARS AGO AND THEY STILL WORK FINE..
Why fart and waste it when you can burp and taste it!
Image Image Image Image
65f100_Thug
Re: Hood Hinges
Post by 65f100_Thug »
I had the same problem and did mine alot of good by taking the springs off and welding on the big brads on the side that looks like a nail head. I used a rod welder and got them real red hot. While they were red hot put them on the end of a sledge hammer and used a pin from a tractor implement and another sledge and whammed down real hard on the other side. It tightened them up. However this is a two man job and I guess you could grind the weld and make them look better but they turned out kinda ugly but it worked.
HAVE YOU DISASSEMBLED A FORD LATELY?
10136 98349929981298119816
GJ1963
Re: Hood Hinges
Post by GJ1963 »
Thanks to Darren, my truck looks a lot better now. He sent me a set of good used hinges, and what a difference. Mine did have broken locating pins. They did not articulate at all. Used to take 5 minutes to close the hood, pushing it one way or another. Now the hood sits right and closes in one complete smooth motion. I even fixed the safety catch which had been badly bent and had to be manually pushed into place. Here is how it looked when I got it:
How it looked once I had the hood pushed into placed and how it has been since I have been driving it:
....And how it looks now.
Thanks again!
65f100_Thug
Re: Hood Hinges
nice! that's what i need!
65f100_Thug
Re: Hood Hinges
dbrady
Re: Hood Hinges
Post by dbrady »
Excellent news and good looking truck by the way.
Darren
2010 F150
1967 Mustang Coupe
1966 F100
