trouble on DD lane
- Anthony's Son
trouble on DD lane
So yesterday I developed a miss.. No biggy, i just changed plugs, wires, cap, and rotor.. So possibly a bad plug.. Take them out, put the old ones back in. Still has a miss, went to leave work this evening (local parts store) and my gen light comes on... Hmmmm.. Okay well my lights are still bright, radio is fine, drive her home and get a meter, and sure enough 12.35 volts.. So its alternator time! Horray for full time college student, part-time job pay!! haha
Zak
1963 uni short bed
sub framed tubbed
351W carbed and C6 are the plans now..
1963 Short bed Flareside
302 3 speed
Daily Driver
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
William-in-St George
Re: trouble on DD lane
Are you using points? Why change the plugs to cure a miss? A diagnosis would be in order prior to changing any parts. The generator may be giving up but it could be battery, battery cables, regulator or even as simple as a weak ground. Again do a bit more diagnosis before you swap out the generator. Swapping in a alternator conversion is good money spent. You can delay this repair for a while by charging the battery when parked and just driving back an forth to work for now. Carry a spare battery and some cables just in case. Save your money and then do the swap. That employee parts discount will help!
William-in-St. George
- Anthony's Son
Yes it does still have points and the plugs were under warranty. Battery is good and it already has an alternator on it. I was afraid to drive it today. I usually drive it 70+ miles a day so I didn't know if it would make it.
Zak
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
you know trucks are like dogs in that they sense your fear and if they think you are afraid they will act up.
i do agree with William,
the 12.35 v does not mean the alt is bad, check out the other stuff he mentioned.
- Anthony's Son
Well guys I have 40 lbs compression in cylinder 1 and 2, and 115-125 lbs in the rest. Also did a leak down test and have 100% leakage between 1 and 2.
Zak
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
- ezernut9mm
yeah, that's not good.
- Anthony's Son
Yea I'm hoping that is all it needed.
Zak
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
- ezernut9mm
hg maybe?
Blown head gasket too replace should take care of MISS. Ck atl regulator plug may be loose on regulator. I had to replace plug with single connections. Tony
1966 f-100 ranger,red and white,240,cruiseomatic,3.00 gear,a/c.
- Anthony's Son
Yea guys, It's the head gasket...
but a buddy of mine and dads is taking care of it for me.. I just don't have the time to tear it down and do it.. but ill keep you all updated!
Zak
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
1963 uni short bed
sub framed tubbed
302 3 speed
Daily Driver
What did the plugs in #1 and #2 cylinders look like?
Were they sooted up?
Did they have a green tinge to them?
BarnieTrk
BarnieTrk
