Fan shroud
Posted: October 8, 2012, 2:51 pm
by twall64
Re: Fan shroud
Posted: October 8, 2012, 6:26 pm
by rickairmedic
That looks great although I will have to admit the urge to polish it instead of painting would been hard on me
Re: Fan shroud
Posted: October 8, 2012, 7:38 pm
by MadMaxetc
Looks good. What are the fans and CFM? Are you going to use a controller?
Re: Fan shroud
Posted: October 8, 2012, 7:44 pm
by twall64
Rick , it would look good polished but I didn't think it would go good with the rest of the look of the truck
Re: Fan shroud
Posted: October 8, 2012, 7:49 pm
by twall64
Dan I used a dual fan control kit from Summit I mounted the relays between the fans. I'll get back with you on the specs for the fans.
thanks
Re: Fan shroud
Posted: October 8, 2012, 9:34 pm
by rickairmedic
twall64 wrote:Rick , it would look good polished but I didn't think it would go good with the rest of the look of the truck
Oh I agree with the style of your build polished would have looked like ass but it still would have been hard for me to paint it
Granted if you had polished it theeeeeeeeeeeen you would have to bring the rest of the trucks finishes up to match
Some Flake some pearl a little candy
One of the things I do like about your truck is the average person would look at it and go Hmmmm neat old truck and have no idea of the amount of fabrication hidden under the patinad paint
Re: Fan shroud
Posted: October 8, 2012, 9:59 pm
by twall64
thanks Rick
Re: Fan shroud
Posted: October 9, 2012, 2:45 pm
by charliemccraney
If a guy needed something like that, how much? It can be raw; I'll handle polishing or painting.
Re: Fan shroud
Posted: October 10, 2012, 3:06 pm
by twall64
Charlie around $200.00 + shipping
Re: Fan shroud
Posted: October 10, 2012, 3:17 pm
by charliemccraney
Too rich for me but it sounds about right for a low production item like that.
Have you had a chance to put it to use? I saw something like that in a magazine a while back and the shroud prevented the flow of air at cruising speed and resulted in overheating. The solution was to add some flappers that open and allow air to pass through at speed but close to allow the fans to pull air through the core at low speed and idle. I think they were made out of some kind of rubber.
Re: Fan shroud
Posted: October 10, 2012, 9:45 pm
by twall64
that thought has come up. I'm hopping to get some road time this weekend
Re: Fan shroud
Posted: October 11, 2012, 11:59 am
by twall64
cost can be high on anything that consist of just one part. If you can use the exact same shroud that I made without any changes the cost could get down to around $125.00. There's $30.00 worth of material in it.
Re: Fan shroud
Posted: October 11, 2012, 12:57 pm
by charliemccraney
I understand that completely. It actually sounds pretty good for all that is involved. My deal is that I can do it and the cost/benefit is not good enough for me to take the easy way out. I'm not quite ready to start that project either.
My radiator is different.
I look forward to hearing about the road test.
Re: Fan shroud
Posted: October 23, 2012, 9:45 am
by Max
Nice fab work there!
Re: Fan shroud
Posted: October 23, 2012, 5:13 pm
by bird55
Nice work! I have a ? about the series of holes made in a circle instead of one single arc. I think I know what your answer will be but just curious and trying to learn something new.
Re: Fan shroud
Posted: October 26, 2012, 2:20 pm
by twall64
I used a 1.250 round tool to punch the large radius with on a CNC punch machine.
Re: Fan shroud
Posted: October 26, 2012, 5:18 pm
by Uncle Skip
Terry, is that stainless?
Re: Fan shroud
Posted: October 30, 2012, 10:57 am
by twall64
Skip I used .090 aluminum. I didn't need to use stainless because I wanted to paint it black. I can make you one from stainless if you want.
Re: Fan shroud
Posted: November 18, 2012, 8:35 am
by olliesshop
Awesome work !!!
Re: Fan shroud
Posted: April 29, 2013, 12:38 pm
by shaff64
nice
