Clutch & Brake Bearing, and Linkage Upgrade
MadMaxetc
Post by MadMaxetc »
My Build Thread
Re: Clutch & Brake Bearing, and Linkage Upgrade
Pictures on both posts do not seem to follow link
foodstick
Post by foodstick »
Wow, what can be said besides you have turned an old hammered out piece of 18th century mechanics into a precision machine ;)
Rusty 63
Post by Rusty 63 »
Could you bend a small "z" into the rod going thru the floor to save the rubber?
MadMaxetc
Post by MadMaxetc »
You would have to do 2 Zs to run it through the floor in the same spot. But just using normal ends would do the same thing.
Some of the pictures follow the links, others don't...I will look into that.
My Build Thread
I got them now. pop up window asks if I want to view only secure web content If you hit 'no' the pictures appear.
Great tips, thanks
