DAKOTA FRONT END
DAKOTA FRONT END
HAS ANYONE DONE THE SWAP ON A 63 AND WHAT KIND OF PROBLEMS DID YOU HAVE AND DID YOU LIKE IT
rickairmedic
Re: DAKOTA FRONT END
Steve over at Industrial Chassis makes the kit . There are several members here who have done the kit and are quite happy . Really its mostly a question of how much money you want to spend . The crownvic crossmember will be cheaper than the Dakota setup but there are alot of guys that like the dakota kit due to the fact it is narrower than the crownvic one .
Rick
Rick
- jkimbrel65
Did it on my 62 uni.Love it.Few minor problems.Was almost to easy.
Mike
Mike
I tried being normal once...
was the worst 10 minutes of my life
Love mine. No problems with install just make sure to get the v8 dak springs.
I don't know if the new kit offers a 5x5.5 pattern but i used 90 dodge truck brakes
to get the 5x5.5 on all four corners.
When I die Bury me with my guns next to that guy who was buried in his Jag.
That way when the Rapture comes I can car jack him and ride to hell in style.
- PFM-64f100
I also did used it on my 64. No problems at all the new cross that is sold now is easier to install than mine (not that mine was that hard).
going with the 5x5.5 will be my next thing once it is time to redo my front brakes. That might be a while.
64 F100 short bed-style side-460-c6-with side toolbox and Dakota Front Suspension
And a 65 CrewCab
Chris W.
The pickups
65 Crew Cab
http://www.purpleflyingmonkey.com/CrewCab/index.html
64 F100
http://www.purpleflyingmonkey.com/1964- ... index.html
The Torino project http://www.purpleflyingmonkey.com/1971- ... eFile.html
And a 65 CrewCab
Chris W.
The pickups
65 Crew Cab
64 F100
I did mine on a 63. No problems, BUT you do have to cut out half you VIN on the frame. So make sure that you check and make sure you have the second VIN stamped under the cab on the passenger side. In KS that is the one they use. They don't care about the door "warranty" tag.
