The plan is to get the cab done, then remove the rest of the body, fix the front clip up a bit (new fender, sand & prime the rest), then repair the bed. This is FAR more extensive than I had originally planned, but once I found out that I was going to have to replace the cab, I decided that since I was taking most of the truck off the frame, I might as well just take it all off and do it right.
I've restored a LOT of boats- But never a truck... So I'll be asking a LOT of questions as I go. And, if you see me doing something incredibly stupid, Smack me in the face. I'm learning as I go!
I figure the easiest way to go about it will be to strip and fix any issues on the bottom, including the floors, first- then flip it back up and do the rest. So, first I flipped it so I could work-
There was a lot of black 'gunk' on the bottom- At this point, I had already let some stripper sit on it for a few hours, then I knocked off most of it off. I'm not sure what it is, it seems like tar of some kind, it's semi-soft, and is a real treat to get off... But, it is probably what kept the metal protected and relatively rust free.
Once it was off, I could see the extent of damage to the floor. This is the drivers side- There are a few holes, but not too bad. The passenger side is MUCH better. I can see I'll be welding a few patches in, but it's far better than what I had before-
And, after a bit more work-
It amazes me what can hind behind paint! Some areas that looked fairly solid were, in fact, not-
Up on the cowl, there was a spot that had a TON of bondo... The thickest was almost 2"! I'm going to cut it out and replace the sheet metal, it's pretty nasty.
The cab mounts are, in general, good. There was a bit of rust in the bottom of the drivers side mount. I'm not sure how I should handle it- Weld over it? Cut it out and patch?
-Andrew
