Best source for new seat belts?
Posted: May 2, 2011, 2:28 pm
by BigMike
I'd like to install new ones in the Slick when redoing the interior.
Suggestions?
Posted: May 2, 2011, 2:33 pm
by Bill W
Posted: May 2, 2011, 2:36 pm
by BigMike
Just found these folks.
http://www.gotbelts.com
Is there a way to at the 3pt. anchor to the corner of the cab without messing up the paint? (welding)
Posted: May 2, 2011, 2:38 pm
by BigMike
Thanks, found them too.
I'd like to put in a 3pt system but don't want to weld in the cab and mess up the outside paint.
Posted: May 2, 2011, 5:01 pm
by qwertyd10n
I ordered a set from Retro Belts (http://yhst-95280463928743.stores.yahoo.net/index.html) a while back. Just about ready to install them... quality looks great though.
Cheers,
Dion
Posted: May 2, 2011, 5:24 pm
by BigMike
Did you get 2 or 3 point?
Posted: May 2, 2011, 5:27 pm
by qwertyd10n
I got the 3 point with the chrome aviation style buckles. I think they should look and work good in my truck.
Posted: May 2, 2011, 5:36 pm
by f100matt
I installed three point belts in my tuck and didn't have to weld on the cab. There is an thread on this site somewhere about installing them. I'll see if i can find it...
Posted: May 2, 2011, 5:38 pm
by f100matt
Posted: May 2, 2011, 5:52 pm
by MadMaxetc
I used those (3-point chrome latch) in my 67. I will look for something else in my 63.
The retract is realy touchy. You have to pull them out slow. The latch doesn't always just click, you have to stick it in almost perfect.
Not un happy, just not realy happy with them.
Posted: May 3, 2011, 7:10 am
by Motocentro
Follow this to a "T" and be EASY with that drill bit into the column. might even want to consider employing a piece of string and get a magnet ready. I may have deviated with the "reach around" solution (not sure why at this point) but i pretty much used Charlie's methodology.
To this day one of the best upgrades I've done ... of course I drive like a bat out of hell when "commuting" across my fair city and being strapped in helps.
:twisted:
J
Posted: May 3, 2011, 8:08 am
by rwhistles
So what is the right length to get? Wouldn't want to end up with to much or to little belt.
Posted: May 3, 2011, 12:25 pm
by BigMike
Excellent, thanks!
I was thinking of buying these. Wonder if this has the same retractor.
http://www.gotbelts.com/retractable-lap ... 1/view/116
Posted: May 3, 2011, 12:31 pm
by Moose
You can also try these guys too. They've been around awhile, used to see them in Mustang Monthly back when I had my 66 coupe.
http://www.ssnake-oyl.com/
Moose
Posted: May 5, 2011, 11:47 am
by BigMike
I started sanding the inside of the cab floor last night and siphoned the gas out of the tank. I still need to remove the emergency brake assembly. I've looked at the links here to get the t-handle off but don't want to cut/split/break it. I have a couple of ideas.
I ordered a lot of parts from DC on Sunday night so that stuff should be here today or tomorrow. My schedule is as follows.
Thurs/Friday after work
- Remove the gas tank
- Sand cab floor
Saturday
- Finish sanding cab floor, kick panels, and rear of the cab
- Sand gas tank
- Sand steering column (power steering column that is red)
- Prime gas tank, steering column, floor, kick panels, and rear of the cab
- Sand/Wire Wheel firewall from the brake booster to the pedeals
Sunday
- Paint floor, kick panels, and rear of cab Caribbean Turquoise (CT)
- Paint gas tank (most likely) Wimbledon White (it's CT)
- Paint area of firewall black (the entire firewall will be painted CT in the future)
- Disassemble pedal assembly (taking it to get powder coated next week)
- Disassemble heater assembly and paint
I want to be able to start reassembling everything a little at a time next week and weekend. I'm hoping to have the seat back by 5/19 which should be the last thing that I need to install. I want to make it to the Norcross car show on the 21st (if something doesn't come up).
Parts to replace:
- Heater Core (while I'm in there)
- Heater Hoses
- Reman Power Steering Gear
- Reman Power Steering Pump
- Power Steering Hoses
Posted: May 5, 2011, 11:55 am
by charliemccraney
The easiest way I've found to deal with the brake cables is to remove the assembly from under the dash. Once that is done it is easy to maneuver it in order to remove the old cable and install the new. You will need a big screw driver to remove the screws from under the dash. If you use a small one, you'll probably just chew up the screw heads trying to get them out.
Posted: June 7, 2011, 1:48 pm
by BigMike
Does anyone know what length to get for the 3 point seat belts?
Posted: June 7, 2011, 2:41 pm
by qwertyd10n
BigMike wrote:Does anyone know what length to get for the 3 point seat belts?
Hey Mike,
I believe I ordered two of these for my truck:
http://www.retrobeltusa.com/products/details/id/2
I also ordered a non-retractable lap belt for the middle seat spot and I ordered the 60" version.
I haven't got them fully installed yet, but they should be plenty long enough.
Cheers,
Dion
