Horn repair
Posted: January 23, 2011, 10:29 am
by Marty in PA
Have to perform surgery on the horns. Any idea how to remove the horn button in the center of the steering wheel on a '65 F100?
Thanks,
Marty
Keep warm!
Posted: January 23, 2011, 11:58 am
by Fanatic
Push down and turn counter-clockwise !
Posted: January 23, 2011, 7:51 pm
by Marty in PA
That worked but it looks some internal patrs are missing ie the contact brush. Any idea where to find a diagram? I would like to what supposed to be there before looking for parts..
Posted: January 24, 2011, 6:31 am
by Jonas
Marty I am trying to to do same thing. I would like to see a diagram of what should be there. I have the center piece and a large spring. I think I am missing the small sping conducter.(can be bought for less then 10 bucks from DC. I think there might be a rubber piece needed too.
Posted: January 24, 2011, 8:42 am
by Marty in PA
It is obvious someone before me removed the steering wheel (or tried). I'm kinda thinking some other parts might me missing once I get the steering wheel off take a look around.
Yeah I have seen the catalogs like Carpenter, MAC etc parts aren't expensive. If it needs other parts though I would like to begin by knowing what supposed to be there.
If I find an exploded view I'll let you know.
Marty
Posted: January 25, 2011, 7:22 am
by DV65CustomCab
Is there one in the LMC catalog? It may be accessible online. From memory (and I've had mine off a few times) it's the chrome buttone, the 3 prong plastic retainer, the big spring over the nut. There's the small spring/brush thingy that goes in the little hole towards the bottom. To go further I think you have to remove the big nut and pull the wheel or at least the metal plate (?) and there is a second spring/brush down there somewhere.
As always, you're welcome to stop by my freezing cold garage and I can twist the knob off for you. :)
Posted: January 25, 2011, 8:40 am
by Marty in PA
Thanks. I have been wanting to cross the river and visit you just haven't gotten there yet.
Marty
Posted: January 25, 2011, 9:31 am
by slickmainer
im not at my desk to look at the real books, but here is a pic i have had. it might help?
Posted: January 25, 2011, 11:29 am
by Marty in PA
Thanks!
Great Stuff.
Marty
Posted: January 25, 2011, 3:16 pm
by Fanatic
Man there's ALOT of parts in a column...............note to self........DO NOT take column apart !
Posted: January 25, 2011, 5:03 pm
by Marty in PA
good advice. I'll stick to te horn.
Posted: January 26, 2011, 7:45 am
by DV65CustomCab
I'd like to get a 'spare' column to take apart before I'd ever attack mine. Either that, or it gets shipped to Flashback Tom for a rebuild.
Posted: January 26, 2011, 9:51 pm
by 65 66 Ford
The hardest part of rebuilding the steering column is removing the wiring pins for the turn signal switch and horn from the two plastic connectors. Just make sure that you mark the location of the wire pins.
Posted: January 26, 2011, 10:23 pm
by DV65CustomCab
65 66 Ford wrote:The hardest part of rebuilding the steering column is removing the wiring pins for the turn signal switch and horn from the two plastic connectors.
The hardest one is the first pin. After I figured it out the rest were done in minutes, but they are fussy little things.
Posted: January 27, 2011, 8:34 pm
by 66fordtrucknut
Fanatic wrote:Man there's ALOT of parts in a column...............note to self........DO NOT take column apart !
I'm trying to never take anything apart again.
Charlie
Posted: January 27, 2011, 8:42 pm
by DV65CustomCab
Charlie
But you've got excellent experience at it. :rotflmao:
Posted: January 27, 2011, 8:51 pm
by 66fordtrucknut
Wish I had the experience of putting them back together. I'm still trying to get Subaru back together. What a PIA went from a cv replacement to ball joints now wheel bearings, had to take the whole lower control arm/hub off to cut the balljoint in half with a grinder to get it apart and the pinch bolt was rounded off by a po, thats how my weekend went last weekend, oh plus snapping off 2 breaker bars getting off the axle nut.
Charlie
