Need Help
- slickmainer
Hey Gregg, Yea I was wondering what to use to install the rubber and brackets to the new division bar channel. My kit is a rebuild kit and I have to transfer the old brackets to the new channel, and rivet the new rubber to the division bar with I think are brads. Thought they were pop rivets but their not.slickmainer wrote:are you asking what to use to pop them into the vertical division bar and door? I recall using a narrow piece of wood and a hammer. some of the rivets on the fuzzies were larger than the hole in the door so i had to drill the door hole a little
- slickmainer
ah, the kit i bought had the division bar included and i just had to fit the fuzzies to the bar then push them into the holes in the bar and the door.
see if these help
http://fordtruk.com/forums/viewtopic.php?t=10201
http://fordtruk.com/forums/viewtopic.ph ... c&start=80
http://www.supermotors.net/registry/17895/69956
see if these help
--Gregg--
you can't get there from here
- slickmainer
