let's just pretend for a minute...
- ezernut9mm
...that i could scrape up the 9 bills for front and rear monos, and i mean the reversed eye monos. 4" front and rear drop. what mods would i have to make to the steering to make them work? or would i need any?
http://nolimit.net/prodinfo.asp?number=6164FTRR
You'll need a can of PB Blaster, some heavy duty elbow grease (or an impact), and maybe a set of new U bolts too.
That's about it.
They basically bolt in my friend.
If you want to use the impact and don't have one handy drive her up here (my compressor won't fit in the Jeep) and we'll make a day job out of it - beer is on me.
That's about it.
- ezernut9mm
cool. you buy the beer and i'll get the steaks. i was not sure if the pitman arm needed changing or if the tie rod ends would need "relocating". sweet. i got tow bills in the sock drawer. just need to save seven more.
- ezernut9mm
duke, see you in nebraska this spring some time? lol
- Alan Mclennan
So the uni is staying around for awhile then Chris!
, mate your link isn`t working!
- charliemccraney
It's just one of those things you have to install and then see what's required. I was told I was going to have to correct all sorts of things with my 3" monos. Other than the springs, I didn't have to change a thing.
Lawrenceville, Ga
1961 F100 Unibody
1961 F100 Unibody
Hey ezer just let me know too and ill drive down to gregs and help to
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
460 stock other than a double roller timing chain and a s475 TURBO pushing 6psi of boost (now 12lbs)
351 W Pulled and on garage floor in storage
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
home made ladder bar rear with air bags
11.96 sec @ 110mph 1\4mile (best with the 428)
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
- Johnny Canuck
My buddy Ger and I went to Denver one time to pick up his BBW uni with monos (since sold). I would recommend some shorter shocks that work with the lowering. You could hardly put a loaf of bread in the box anymore, as far as carrying capacity went, but it rode pretty nice.
Brian Taylor
Michelle's red/white '65.Brian Taylor wrote:Now pretend you had the money to do anything you want to your slick........What would it look like??????
My '65 wouldn't take much to get there, but what a bang up job on that red/white slick.
1965 F250 352 4spd/Dana 4.10 (sold)
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
2011 Jeep Grand Cherokee - yeah, it's a HEMI
Chris,
you can get a similar stance as my 64 with only the front monos. Keep in mind my rear tires are taller than the fronts. Rear is the F 250 spring pack with all but the top 3 leaves removed - shouldn't be tough to round up a pair of them. As far as I can tell so far the ride will be pretty nice and it will still have a little load capacity. You could also leave a couple of the overloads in the pack too for a bit more load capacity.
I don't personally think I would go with monos on the rear.
We could also lengthen the shackles like Todd did on Tim's Land Speed Racer Uni - Maybe flip the springs under that axle too?
- ezernut9mm
i have been thinking about flipping the axles. a friend says he might be able to hook me up with a guy that can get me all the hardware i need.
the ride is pretty soft now, so i wasn't sure if removing springs from the packs would be a good idea. wouldn't that soften the ride even more?
i could get away with the rears the way they are and do a hanger flip like i did on the 68. worked well and was almost free-i like free.
so maybe a rear hanger flip and a front axle flip would be the way to go.
so many ideas and not enough beers. lol
sounds like either way we might have a shot at an upper plains get together sometime before spring starts.
Wish I'd read that before I did my rear monos!truckster wrote:btw, im not sure of the advantages of monos but i did my lowering for about 300 bux total if you were maybe thinking of trying to get by a little cheaper. just find a good spring shop in your area
Do you have any pics of the springs themselves or the process?
