Cant Kill a Y-Block....
f100fordguy
Post by f100fordguy »
Pulled motor today and found out where my loss of compression was in the 292. Am very glad it stayed together during slickstock as my bad piston came out in pieces :oops: Took a pic for you guys to see how bad I killed it. Next slickstock she will be bigger and badder and might even be able to drive it there!
http://www.fordtruk.com/forums/album_pi ... &user_id=7
Tim
Gotta love them y blocks
resurrect the old girl I say
64low-n-slow
Post by 64low-n-slow »
That's impressive. You're probably gonna need a stroker crank and some of those aluminum heads from Mummert's to even put that baby together again (just in case you have a wife who reads this).
Keep us posted.
f100fordguy
as of right now its .060 over. unsure if it origionally was a 272 or 292 now but gunna go to at least a 312 std bore and get a isky cam and put big valve heads in it. Im still debating throwing msd in it, all depends on budget this winter but should be a really strong runner once i get done.
ezernut9mm
Sweden
Post by ezernut9mm »
damn tim, i'd say that'd let some compression out.
Lowell
Post by Lowell »
Looks like another job for JB Weld LOL.
Gritsngumbo
Post by Gritsngumbo »
You beat me to it :-).
Lowell's correct! Remember it's a Y-Block not an FE. JB Weld it, put it back in and you should be good for another 100,000 miles.
BIG RED: 62 F100 Long Uni
BIG “UN": 63 F250 Long Flare
charliemccraney
Post by charliemccraney »
f100fordguy wrote:as of right now its .060 over. unsure if it origionally was a 272 or 292 now but gunna go to at least a 312 std bore and get a isky cam and put big valve heads in it. Im still debating throwing msd in it, all depends on budget this winter but should be a really strong runner once i get done.
.060 0ver 292 is .010 0ver 312. At that size, sonic testing will be wise, even with a Y block, and particularly if it is a C2AE block.
A good alternative to MSD, if you plan to use a box, is to convert to a Duraspark trigger. It's basically what MSD uses anyway, and much cheaper. If it's not something you want to do yourself, Performance Distributors can provide a Durapark distributor, custom curved, to fit your engine. The biggest downside to the Duraspark route is that you must use a box, while the MSD does not require a box.
Lawrenceville, Ga
1961 F100 Unibody
kjvforme
Post by kjvforme »
What about sleeving the block back down to 292?
1962 Ford F100 Unibody Custom Cab
1944 Ford GPW
charliemccraney
kjvforme wrote:What about sleeving the block back down to 292?
Not cost effective. In my area, to sleeve 8 cylinders is about $1200. You can buy 4 or 5 engines for that and find a good one to rebuild easily.
Lawrenceville, Ga
1961 F100 Unibody
MadMaxetc
Post by MadMaxetc »
Just grind the oil grove a little bigger and put a hose clamp around it! :shock:
My Build Thread
matt2491
Post by matt2491 »
One time I was doing a burnout, and suddenly the rear end blew up, and the 292 went straight to the moon. I saw the RPM needle rocket to 8k and drop back down!
It didn't even cough. It's a stock 200k motor that's the only thing on the truck that's never given me any trouble.
Yep, you can't kill a y-block.
Just driving my truck.
RhodySlick'63
Post by RhodySlick'63 »
Half price piston sale?
'63 F100 292 Y-Block
jakdad
Post by jakdad »
Back in the mid 60s I had my 292 bored to a .060 over 312. It lasted a long time. A spun bearing finally got it. :lol: :lol:
Jim
64shortie
Post by 64shortie »
Over and over again you guys keep making me happy I stuck with my Y block.
Love those little square trucks
64 F100 short cust. cab
Custom built Harley FXSTC
2000 supercharged Bonneville
