King Pin Help
DavidNevada
King Pin Help
Post by DavidNevada »
My left front wheel is VERY loose - probably moves a least 5 degrees if you grab the wheel at 12 and 6 O'Clock with it jacked up. My mechanic says he would remove the entire i-beam and have it machined for an oversized bushing. I read here on slick 60s some guys recommend using the nylon bushings to avoid the trip (and the $) to the machine shop.
My neighbor is retired but owned a service station/garage back in the day. He says we could simply leave the i-beam installed on the truck and knock out the old bushings with an air chisel. Then we would re-assemble with the nylon bushings. He says it is unlikely the bushings on the spindle would need replacing.
Opinions? I've never done king pins and I'm not afraid to try, but I don't want to mess up my truck with a brute-force approach. Nylon or metal? Air chisel or ????
F7BIGJOB
Location: West Greenwich, Rhode Island & Providence Plantations
Post by F7BIGJOB »
I've done a ton of them on buses [18 years in that industry] they all had bronze, we used to install them and ream them to fit the pin. When I worked for my uncle, we had a '68 C40 tow truck and we were constantly replacing pins/bushings [320+K miles by 1979] they had nylon bushings that didn't wear out, but would wear the axle. I'd stay away from nylon myself. :2cents:
-Steve.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
DavidNevada
Thanks. Did you ream the new bushings with the i-beam still on the truck?
F7BIGJOB
Post by F7BIGJOB »
DavidNevada wrote:Thanks. Did you ream the new bushings with the i-beam still on the truck?
Yes.they only time axle was pulled was 'cause it was worn as well.
If I remember right, we had 2 or 3 different ones depending on the size.
-Steve.
butbut.gif it's been aboout 16 years since I've done ANY old.gif and I think we only ever had to pull 1 axle as the hole was too worn out for the pin.
Thanx Don, I knew they are in spindles, didn't 'click'=Steve
F7BIGJOB
-Steve
don morris II
Post by don morris II »
the bushings are on the spindle not the i beam so you leave the i beam on the truck you remove the spindle hope this helps :D
FORD, FAST, FLYING, FIRST, ALL START WITH F IS,NT THAT "SLICK"
DavidNevada
Thanks Don. I guess I'm not understanding the assembly. The kingpin does go thru the end of the i-beam - yes?
don morris II
yes
don morris II
the pin is locked in the i beam with a tapered pin and does not move the spindle pivets on the pin so the bushings are in the spindle
ezernut9mm
Sweden
Post by ezernut9mm »
please don't get the nylon bushings or "no ream". they are junk. they have my company sold on them and they wear after less than a year on big trucks.
get the metal ones and have your spindles reamed. you won't be sorry.
F7BIGJOB
Post by F7BIGJOB »
ezernut9mm wrote:please don't get the nylon bushings or "no ream". they are junk. they have my company sold on them and they wear after less than a year on big trucks.
:iagree: That's what I was saying
F7BIGJOB
-Steve
DavidNevada
Thanks guys. I'm kinda embarrassed I had the assemply backwards in my head. I thought the bushings were in the axle. I obviously misunderstood what the mechanic said. But I learned something and that's worth a little embarrassment. I'm gonna go with the metal bushings.
1966 F100 Camper Special Ranger
<img src="http://dt9.com/pics/albums/66ford/angl.jpg" border="0" />
