piston rings
piston rings
I've been reading that cast iron rings are better than chrome if your not having the engine rebored. I ordered a set off ebay that I thought where cast iron but it turns out that the top ring and the oil seal are chrome and second ring is cast iron so I'm trying to decide weather to just throw them on anyway or keep looking for some cast iron rings. If I need to find cast iron rings, does any one know a good place to find them? No one seems to carry them for the 262.
62 f100 262
Chrome or Chromoly
Chrome rings would be very bad to put in any street engine. I bet you meant chromoly filled rings.
They will do fine if they are chromoly, but you need a 400 grit stone instead of a 180 grit that is used with a cast iron ring for the hone job.
TxSlick66
aka MustangSteve
Money you ENJOY wasting is NOT wasted money...
aka MustangSteve
NO WAY I would use those chrome rings
They will NEVER seat especially on unbore cylinders. CHROME rings will use oil terribly. Moly fill is ahat you want.
TxSlick66
aka MustangSteve
aka MustangSteve
http://www.citymotorsupply.com/
I have done ALOT of business with these guys. They can get darned near anything. In Dallas and San Antonio. I always get Hastings rings. My 351Windor in my Mustang has 50k miles on it now and never has used a drop of oil, using the Hastings moly rings.
Your results may vary if you do not bore it out. It is hard for a new ring that is ROUND to seal in an old cylinder that is OVAL shaped.
TxSlick66
aka MustangSteve
aka MustangSteve
- don morris II
never use chrome rings in a rering job only in new boars. oil rings are almost always chrome in older engines and are used in a rering job but compression rings are another story. in a rering use moly,plasma or cast. chrome will not seat in a used boar. newer engines use a nitrated oil ring. hope this helps
FORD, FAST, FLYING, FIRST, ALL START WITH F IS,NT THAT "SLICK"
well its looking like all they sell are chrome rings for this engine and I can only find one set of those available directly from Hastings. This might bring my project to a halt. There are some on eBay but they are ether standard or 30 over. Mine is 20 over so may need to pull the block and have it re bored to 30 over to fit those rings.
62 f100 262
- olliesshop
I've been reading this thread hoping you come up with a solution to something that seems like a simple problem at first glance. It looks like you're getting closer, though. Good Luck !!!
Tim - 1961 F250 Uni
"Big Red" pictures ... http://olliesshop.smugmug.com/Trucks
Current build thread ... viewtopic.php?f=32&t=29505
These folks can fix you up.............debauchee wrote:well its looking like all they sell are chrome rings for this engine and I can only find one set of those available directly from Hastings. This might bring my project to a halt. There are some on eBay but they are ether standard or 30 over. Mine is 20 over so may need to pull the block and have it re bored to 30 over to fit those rings.
http://www.hastingsmfg.com/
Jim
Thanks jakdad, I think I'll try calling them to see what they have. I'm also eying this on craigslist.
http://seattle.craigslist.org/kit/pts/1943225567.html
If it really is in good shape, it might be better to just clean up this engine, throw my manifolds on it, and get back on the road.
62 f100 262
