So much fun Im gonna do it again
Ford4jack
Post by Ford4jack »
Went up to reeses66ford home for wayward slicks lat weekend and did some trading with her. I ended up getting a 65 3/4 ton frame to put under 66 1/2 ton. Its a hard call to make on swapping frames because I have only had my truck together for a month or so but I have a fridge box I have been wanting to use and this should allow me good route to go. I need to shorten the frame 5 inches if I remember correctly and this time sandblast the frame. I used a rust killer on the current frame and its been haunting me that I did that. At least everything will come apart easy this time and I will be able to swap parts in bigger chunks.
MadMaxetc
Post by MadMaxetc »
if you used a good rust converter, then you should be ok. If you do have the body off, then go for the sand blasting!
My Build Thread
