ext cab slick??
ebentraywick
ext cab slick??
is there even a ext cab slick or just a story?
owning a slick.,,, priceless
1961 ford f350
1959 ford f100. not a slick but still goood looking
1961 ford f350
Supercab Slicks were made post manufacturer only I believe. The rear section is a little longer than what you would see in a more modern truck. Some of them had a cut down bed that placed the wheel arch nearly at the cab corner.
http://fordtruk.com/forums/viewtopic.ph ... t=supercab
Extended cabs are all jobbered to coach builders or home built. Crew cabs were coach built and the Ford assembly plant in Ontario began production of factory crew cabs in 1965.
Garbz
Garbz
64 F100 Christine "Heartless" and Mean.
63 F100 Uni Custom, Cammer. T56 Low and fast. Still under the Knife
69 M250 Crew Cab 4x4, 472 EFI, Ranger, CC, Long bed
05 Escape.
All Ford and nutthing but Ford.....
05 Escape.
- MattsIASlickShop
ebentraywick
Matt is messing with you, he built a Merc with an extended cab, with a Jag rear AND quad cab rear doors!
Matt - you a far too good of a fabber to not finish that absolutely killer ride.
ebentraywick
