clogged drain
A place for discussion of off topic subjects. Pretty much anything goes - just keep it civil, please!
DukeRoche
clogged drain
Post by DukeRoche »
I went out to my new garage and saw that water had built up around the drains. I tried a snake but it didn't help much. Any suggestions for a cheap way to do this? This is of the utmost importance because thats where the Green Machine will be stored with all its parts. Any help would rule
The Green Machine
GO ARMY, BEAT NAVY!
Alan Mclennan
Australia
Post by Alan Mclennan »
Why didn`t the snake work?, are these old drains or new, where do they go to?, any pic`s of the location?
Gritsngumbo
Post by Gritsngumbo »
You say it's a NEW garage. New construction or just new to you? Has it drained previously? If new construction it may be that some concrete or other debris has blocked the drain? Just a thought.
Now if you only had a nice air compressor. :-)
BIG RED: 62 F100 Long Uni
BIG “UN": 63 F250 Long Flare
DukeRoche
Post by DukeRoche »
Actually the snake must have worked cause I went out an hour later and it had gone down and has since disappeared. But a new air compressor would be nice. Not sure how old the garage is but I know the house is 30 years old and the garage is much newer then that. Will post pics if problem continues.
The Green Machine
GO ARMY, BEAT NAVY!
kstones63
Post by kstones63 »
With a new air compressor, you could blow out that clog instead of using a snake. :lol: Use that one to justify it with the wife.
kstones63
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
MattsIASlickShop
Post by MattsIASlickShop »
is it still cold where you are?
Chances are, the floor drain runs out under the yard and ends in a bed of gravel. I tend to think maybe it was/is too frozen to drain well
DukeRoche
Post by DukeRoche »
Not to cold here, has warmed up some. But I love the new ideas for the air compressor. Keep them coming
The Green Machine
GO ARMY, BEAT NAVY!
Greg D
Post by Greg D »
I don't think I would point an air hose into that muck and pull the trigger, lol.
There is a drain cleaner out there that hooks to your garden hose. It's a rubber bladder with a pressure seal in it, it swells up and after the pressure gets high enough it will then release into the pipe, blows the clog out. I have seen them a few places HF has them.
