Proper way to change and clean oil bath Air Cleaner?
- ripsnorter
I havent noticed this posted around here, I'm sure its probably very simple but I'd still like some tips before I tear into it. I'm not even sure what oil you're sposed to use.
- Paul Merrell
I have a lube chart and it recommends change the oil every 4 months or 4,000 miles It recommends above +32, 30w below +32 20-20w . I would drain the oil and clean it with diesel fuel and dry base. Fill with oil to the mark in the base .
"Never underestimate the power of your actions. With one small gesture you can change a person's life - For better...or for worse." 1965 F250 4wheeldrive 390/4speed/dana 60 rear 3.73/dana 44/PB
