Who has put a 460 in a straight axle truck?
36truck
Post by 36truck »
What needs to be done for this swap?
Tom Williams
61 Merc
Post by 61 Merc »
I know of a 61 Merc that has a 460 in it, what you need is a 460 ci engine and a good straight axel truck.
Time to go shopping again Tom. :rotflmao:
Dean
ps. The truck I saw is owned by HeavyD460 on the forum, though I don't think he has posted at all. It is tight getting it in, but it does fit.
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
ridgerunner
Post by ridgerunner »
i put a 429 and C6 in my 62 uni. i made my own mounts for the engine and tranny
ezernut9mm
Sweden
Post by ezernut9mm »
beer is good. you'll need lots of it tom, but since you don't drink your gonna have lots of problems. lol
Phil
Post by Phil »
My truck has a 429/C6 in it.
It appears all you need is a flame saw and a stick welder. If its in the way, burn it off. Best thing to do seems to be pick some random driveshaft and adjust the truck accordingly :roll:
I can take pics at some point but it would be more of a "how not to"
36truck
Post by 36truck »
Look at all the love I get. :rotflmao: Thanks Phil hope it will at least give me some ideas to go ahead or i'll just stick a chebbie in it. :rotflmao:
Tom Williams
PFM-64f100
Post by PFM-64f100 »
Ok I will help you tom... :D At least this is how I did mine.
First you will have to remove this cross memeber and use a universal Tranny cross memeber.
[albumimg]5862[/albumimg]
You should end up with something like this.
[albumimg]5863[/albumimg]
Next you will need to get one of these. This pic is from LMC but there are a lot of univeral 429/460 cross members.
[albumimg]5861[/albumimg]
If you want to run headers Sanderson has some shorties that fits the 64. The biggest problem with headers is clearing the steering box....
When you buy your univeral cross memeber just be aware of the cheaply built ones. I had this failure and it was not fun... Nearly pushed a mustang into an intersection because I hit the gas with brake on and the motor toqured up and jammed the thorttle.. Not fun by any means good thing that mustang got out of the way and the motor went to normal postion...
64 F100 short bed-style side-460-c6-with side toolbox and Dakota Front Suspension
And a 65 CrewCab
Chris W.
The pickups
65 Crew Cab
http://www.purpleflyingmonkey.com/CrewCab/index.html
64 F100
http://www.purpleflyingmonkey.com/1964- ... index.html
The Torino project http://www.purpleflyingmonkey.com/1971- ... eFile.html
36truck
Post by 36truck »
Chris does the front cross member stay?
Tom Williams
PFM-64f100
36truck wrote:Chris does the front cross member stay?
If by front cross member (Where the red screw driver is (right above the words)) you mean the Radiator support then yet it will have to stay.
I only had to cut out the old tranny cross memeber.
Hope that helps, Your question kinda of confusing me.
And a 65 CrewCab
Chris W.
The pickups
65 Crew Cab
64 F100
Phil
Post by Phil »
On mine the radiator support is torched to clear the lower pulley.
I think the driveshaft was 3" too long so they just cut the truck.
Luckily there is a hole in the bottom for a wrench when cranking
the mill by hand.
I too am missing that X member. Its replaced with nothing.
The engine (or integral cross member) rests on two wedge shaped chunks of stick welded iron.
ABA
Post by ABA »
I put a 429 in a '55 F100.
Only problem I had with it was it kept leaving black marks on the pavement. 8)
'01 F150 Lightning
490RWHP
Gas Mileage? What's that?
Jerry
36truck
Post by 36truck »
I think I need to get the truck here so I know what I'm looking at. I thought the crossmember was also the engine mount. But now seeing it & thinking about it. It looks to far forward.
So I need the crossmember you said about & do I need a trans crossmember also?
Tom Williams
been thinking about 429s lately, saw this today
http://anchorage.craigslist.org/cto/1190385071.html
PFM-64f100
Yes you will need a Tranny cross member. Like this one if your planing on using a c6 I think it might work for a c4 also. You always have the option of using a E40d tranny but then you will have to have a computer which is kinda of easy..
And if the Cross member was where the motor was mounted it's not a straight axle truck which make the swap easier just need new mounts...
[albumimg]5866[/albumimg]
And a 65 CrewCab
Chris W.
The pickups
65 Crew Cab
64 F100
36truck
Post by 36truck »
It will be a 4/5 speed stick.
Tom Williams
oldtrucks
Post by oldtrucks »
Tom
Look in my album and photobucket and see how I did the mounts for the 302. You can do the same thing for the 460 and take the cross member out. I would box the frame in this area a couple of feet and then fab a tranny mount and for the clutch mount you will have to adapt a frame mount to hook up the clutch linkage unless you are going to use a hydraulic clutch which would be a lot easier in my opinion. Measure and have a drive line built and you will be in business.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1962 UNI Short Box, Stock Y block, 4 speed Image
1972 F 250 4X4 429 4 speed Dana 70 rear
1977 F 350 Camper Special, Ranger, Super Cab
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
