What have you done to your slick today??
DanH
Re: What have you done to your slick today??
Post by DanH »
Bought an oiled cotton air filter from Jegs. Spectre brand 17.99. Lots cheaper than K&N. Topped it off with a new wing nut that looks like the inside spokes of an old school wooden steering wheel. Also bought a new Craftsman double box end wrench 3/8 and 7/16 to use as my battery hold down. At just over 7 inches it fits across the top of my Optima battery perfectly. And at about $8 its a LOT cheaper than those billet hold downs. These two things aren't much but they were just what I needed to ease the Slickness. And last but not least I bought a fire extinguisher to put in the truck. I have one in the garage but now I have a small one for the road.
DanH
Very good! You now also have a spare wrench available, as long as you have the correct wrench available to access it :lol:
Like that bumper. Make it?
mrgoob wrote:Installed a set of Per-lux 200T fog lights. Need to wire several accessories, hopefully this week.
Sunday: Replaced brake hoses and realized I ordered rear brake hose for F100. One less part to buy for the 1/2 ton! Got beat off line by an auto Cummins. Caught him at 70 the he quit. Would like to have seen if his speed limiter was on. Must be the sound of an FE that makes every redneck think its a race. 8)
therealjoeshmoe
Post by therealjoeshmoe »
well might as well chime in here, last weekend got the gas tank cleaned out and drained, put new motorcraft plugs, wires, points, cap and rotor on. went and got some new gas and mixed stable in with it this time.. got the headlight wire harness all ran and fixed, mounted a new solenoid and installed a resister to keep form burning my points up.
this weekend im gonna take the bed off and install new center tie bolts on the springs and hook up my new air horn.. :lol:
joey
Why fart and waste it when you can burp and taste it!
Image Image Image Image
GJ1963
Post by GJ1963 »
Stitches in index finger have left me down for a few days. Dr. said no doing dishes for a while. Wife immediately says no dishes means no working on the cars as well right doc? So truck sat a week waiting for more work. Finally feeling a bit better and today I installed the parking brake cables I had been waiting for on it. After that my wife and I put about 40 miles on the truck running errands. Starting to formulate plans for an engine rebuild in late spring/summer. As well as it is running, the 300 is tired, uses oil and smokes a bit.
mrgoob
Post by mrgoob »
chris401 wrote:Like that bumper. Make it?
Chris,
this is a Warn Winch bumper for Fords that a guy had on his '66. I bought it along with a warn 8274-50 winch and a pull-pal winch anchor.
Chris,
Looks like a good enough excuse to buy a 4x4, wouldnt look right on my 2wd.
Rusted64
Post by Rusted64 »
While rebuilding my 292, again, I decided to add a reverse switch to the column shift 3 speed. Figured it was a good time with th front clip off.
Simple momentary toggle, double stick tap and screw clamp.
Thanks,
J
1964 F100, 292ci
1963 Buick Wildcat, 401ci
They just don't make them like they used to.
mrgoob
Post by mrgoob »
Installed anti-rattle kits in both doors of my '62 past couple days. Huge difference.
Lowell
Post by Lowell »
Got a good used temp gauge from Slickmainer in the mail today, got it installed and working!!
MadMaxetc
Post by MadMaxetc »
Got my axle bearings replaced, and the 4-link put together to start mocking up the exhaust.
More work tomorrow!
My Build Thread
WrongBedDave
Post by WrongBedDave »
Been working on a power window conversion based on using the Saturn motors with the factory regulators but with a major change. Ill post video of it tomorrow
Dave
63 Wrong Bed 2WD : 302/C4, drip rails shaved, aluminum radiator/e-fan, 16 gallon fuel cell, "custom" gauges, 1000W sound system
Photobucket Album:
http://s1084.photobucket.com/albums/j413/davewave649/
Build Thread:
viewtopic.php?f=32&t=27105
slickstysix
Post by slickstysix »
Pulled the hood off and radiator out to prep for an engine rebuild!
Somehow I get this nagging feeling that it's not just going to a rebuild. I see new rad support mounts, painting firewall, frame and inner fenders, on and on....
Wish me luck.
1966 SB, 2WD, 390FE, 3x2 6V carbs and intake, 3 on-the-tree (for now).
- Power brakes
- Pertronix electronic ignition
- Ron Francis wiring throughout
- DJM drop beams
- Halibrand Sprint 17x8 wheels
f25065
Post by f25065 »
Installed a correct set of 2 roof clearance lights (one on each side), and while I was wiring them in, played with the headlights switch a little and rewired the front parking lights into the tail lights so that they stay on with the headlights instead of turning off. Looks better. Also threw on a set of '69-era rear reflectors underneath the tail lights, which look really good too; almost correct-looking (tho they're not).
Norm
WrongBedDave
Hoping to get some time to work on the truck today, need to wrap up the overhead console and headliner so i can finish wiring. In the mean time I'm looking in to doing another crank switch conversion for some 70's trucks per the request of a couple locals on another forum.
Dave
Photobucket Album:
Build Thread:
White97
Post by White97 »
Cut out my passenger floor and starting fitting in the new panel from Tom. Nice and thick, fits great. Have to repair kick panel a bit before I finish fitting the floor, and now that the cab support is only held on by three spot welds I'm thinking of replacing them rather than repairing them. They aren't that bad, but since it is wide open now is the time.
Still swearing at the toploader 4spd sitting next to the chassis :cussing: .
That thing has bit me every step of the way. Back from a full rebuild, and now new bearing retainer is thicker than the old one and is hitting the clutch fork. Old one was cracked.
Lou
1965 F100 Short Bed
White97
Post by White97 »
Well that decision didn't take long - ordered my cab mounts from Tom last night.
Lou
1965 F100 Short Bed
mrgoob
Post by mrgoob »
Installed new headlight switch so now my dash lights are working well. Got heater fan working again with a little wiring work.
Installed a top radiator hose on the 61
Checked the oil & added a quart
I need to install a wiper switch :roll:
It's my driver..... Gonna do a 'makeover' on it next winter ( fingers crossed )
