Page 12 of 13
Re: kstones63 project
Posted: February 14, 2012, 10:06 pm
by Greg D
Posted: March 1, 2012, 10:44 pm
by kstones63
Here is the current update.
The plumbing is a nightmare for the radiator hoses but it all worked out.
I got the fender aprons put in tonight. They are pretty close to the heads but there is plenty of clearance for engine movement.
passenger side
drivers side
I took out the rubber that I had between the aprons and the cab because I wasn't crazy about the way it looked. I picked up some weatherstripping and glued it to the edge of the fender apron before I installed them. They look a lot better than the other rubber did. I am assuming that it will hold up okay or at least I hope that it does.
The next step is to get the a/c lines and the heater hoses hooked up this weekend and then the fenders and grill will go back on.
Kevin
Posted: March 4, 2012, 11:29 pm
by kstones63
I drove my truck this afternoon. :clap: :D
I had some problems getting the engine burped but with time and persistance I finally got it done. The engine came to 190 degrees and stayed right there. It really ran good, the transmission seemed to work great and I couldn't be happier at this time.
I guess it's the Lincoln transmission but you can't hardly feel it go into gear and feel it shift.
It sounds great under acceleration and almost a little bit too loud. If I get tired of that I guess I can put the cats back on it and that will probably quiet it down a little bit.
Now I have to get the fenders and grill back on.
Kevin
Posted: March 5, 2012, 9:42 am
by slickmainer
great looking ride Kevin.
Posted: March 5, 2012, 6:06 pm
by Power by Ford
Kevin
Very well done on the engine install. It fits very nice between the inner fender wells. Any issues with computer throwing codes?
Posted: March 5, 2012, 7:25 pm
by TheOPWK
You going to make it out to Goodguys with the truck this weekend?
Posted: March 5, 2012, 8:56 pm
by kstones63
Power by Ford wrote:Kevin
I had this figured that I would have just enough clearance to slide my fingers between the valve covers and the fender wells. That would have been correct but I decided to slide the engine back about another 3/4" so that gave a little bit more room.
It did throw some codes but I knew that it would. I needed to remove the egr valve for firewall clearance and it had 3 codes for that and 1 for the IAC motor. I replaced the IAC and haven't rechecked for codes yet. Now that I have driven it, I need to go back with the code reader and check for driving codes to see if there are any others, hopefully not.
I plan to put a chip in it so I can delete the egr and the purge canister valve.
My neighbor was out when I left in the truck and said that it sounded really good.
OPWK, I am planning on going to the GoodGuys show but I won't have the fenders and hood back on yet so I won't be bringing it. :( :(
I want to get any other codes repaired before I get the body back together. I still need to hook up the O/D switch and I need to find what I want from the vendors at the show.
Are you going to be there with your truck??
Kevin
Posted: March 6, 2012, 12:57 am
by TheOPWK
Yeah, I'll be there for sure.
Posted: March 8, 2012, 11:37 am
by PFM-64f100
Kevin
I got to thinking more today about your setup and I think this will work to delete the EGR. Simple little resetor but it will keep that check engine light off until you figure out what chip your going with. Just a suggestion/thought. The purge canister shouldn't cause driving problems or MIL lights. :)
http://www.rjminjectiontech.com/products/egr-eliminator
Posted: March 8, 2012, 6:57 pm
by kstones63
The piece that they show doesn't match up with my EGR. They say that it will work on most up to 95. I probabl have the one that isn't included in the most.
I have an easier solution to the light. If it bothers me, I will just unhook the wire from the gauge module until I get a chip for it.
I have been looking at the Moates Quarterhorse chip but I think that it is a little bit over my head for right now although the challenge does make me want to got that way. My better judgement is saying to buy a preprogrammed chip and live with it for now.
Kevin
Posted: March 10, 2012, 6:37 pm
by lo6fo
wow i cant believe ive missed this build thread. amazing work
Posted: May 24, 2012, 10:51 pm
by kstones63
I can't believe that I forgot to post a pic of the engine finished with the MAF cover on it.
I have a few other things that I am doing but they are taking time.
If you look at the burp valve, you can see that I got it messed up trying to get it open so I made a cover for it. It is at the chrome shop right now so I can't get a pic of it. I have a couple of other small parts that are ordered and waiting on.
I guess that these projects are never done. There is always something else that we want to change.
Kevin
Posted: May 25, 2012, 9:01 am
by slickmainer
what a great truck. just dont sell it.
Posted: May 25, 2012, 6:56 pm
by kstones63
This truck doesn't ever get sold. It goes in the will so that the kids can't even sell it. :lol:
Kevin
Posted: May 25, 2012, 7:07 pm
by randyr
That engine looks awesome, Kevin!!! Way better than the SBC you had in there!!! :shock: :lol: How does it perform? Are you pleased with it? Looking forward to seeing it at the Western Nationals again this year. :)
Posted: May 25, 2012, 7:35 pm
by kstones63
I will be at the F100 Weatern Nationals this year. We plan to go over on Thursday so we can do the drive on Friday with the group.
I drove it aroound at the Fabulous Fords show and it did about 15 mpg running around in LA. I think that it will do better. It runs really good and smooth. I couldn't be happier.
Kevin
Posted: June 16, 2012, 6:30 pm
by kstones63
Here are some pics of the latest additions. I didn't like the oil dipstick or the oil cap so I found these. The dip stick handle needed some modifications to make it work. I had to redrill a hole in the handle to properly locate the dipstick so it would be accurate. The oil cap is just a cover that goes over the original.
I made this cover for the radiator and had it chromed along with the original mount that I made.
I messed up the burp valve plug with a pipe wrench trying to get it out when I installed the engine, so I made this piece to cover it up and had it chromed.
Now to get the rest of it cleaned up to look like the new parts.
Kevin
Posted: July 12, 2012, 9:58 pm
by ras4434
Kevin, I really wish you would pay better attention to detail....... :shock: Your work is the best and something we can only aspire to. Wish I had even a little of your talent....I could easily be in more trouble than I usually am. GREAT BUILD....
Posted: July 12, 2012, 10:51 pm
by kstones63
ras4434 wrote:Kevin, I really wish you would pay better attention to detail....... :shock: Your work is the best and something we can only aspire to. Wish I had even a little of your talent....I could easily be in more trouble than I usually am. GREAT BUILD....
Thank you, but really anybody can do this stuff with a lot of patience and time. It also helps to have a neighbor that is fussy and likes to help and teach.
Kevin
Posted: July 13, 2012, 8:53 am
by rickairmedic
I love how you hid all the wires for the engine :D. That is going to be fun trick on my 5.0 . The engine compartment in the crown vic looks like the underfloor area of a commercial computer room :D.
