The water inlet comes out on the the side of the block and the hose hit the steering box. I ordered a different one from Ford Racing with the oil filter set up for AN fittings instead of an oil filter so I can relocate that. The water inlet was different than mine but still wouldn't work so I cut up the two parts and welded the inlet on where I wanted it so that it would work.
After the p/s pump goes on, it is getting pretty tight on space again.
I painted the valve covers to match the body color and got them swapped out.
I still wasn't crazy about seeing the intake manifold and injectors, so I made an aluminum cover for that.
I have a large piece of aluminum tubing coming that I am going to cut in half and make a cover for the MAF and the throttle body. I decided not to chrome the MAF.
I am going to have both of these aluminum covers chromed.
I do believe that I am finally ready to start prepping the truck for disassembly.
