Did you consider a aftermarket wiring harness?
Randall
Same here! Are you going to cut out the original gauge housing and do a custom housing? I'm thinking that might be the easiest way to go, just dont want it to be cheezy.390fastback wrote:I'm going to try and incorporate the vic gauges into the orginal cluster.....i'm going to try!
Looks like it should have enough room. I think the problem is where guys do not get the proper offset wheels or the right looking wheel for the vintage, IMO.390fastback wrote:I've been hearing two sides to the story of the CV front end install. Some it fits without issue, some say its just to wide and doesn't work. I needed to find out for myself, so I very loosly installed the rad support and front fenders. I think I'll have more than enough room, maybe even enought to take a coil out?
