Page 10 of 13
Posted: July 18, 2011, 10:44 pm
by kstones63
I am making some more progress on the truck. I changed the headlights over to the clear tri-bar halogen with red dot centers in place of the sealed beams. I also changed out the yellow looking park light lens fro some that are more clear looking.
I am still working on the 4.6 DOHC engine to go in the truck. I built an adaptor to move the throttle body up to the top of the engine instead of tucked down in at the back of the manifold. It was going to be tough to make an air filter work with where it was located.
This should make it a lot easier. This is what I started with.
I made it to this shape.
Here is the throttle body relocated.
This should make it easier to put the air filter and MAF in line.
Kevin
Posted: July 19, 2011, 6:24 pm
by Greg D
Looks great Kevin!
Posted: July 19, 2011, 6:31 pm
by 64Ranger
That looks so cool... you are amazing!
Posted: July 21, 2011, 9:58 am
by sully5
Where did you get your bed cover and what brand? Is it model specific for our trucks or a one-off custom?
Posted: July 24, 2011, 10:39 pm
by kstones63
sully5 wrote:Where did you get your bed cover and what brand? Is it model specific for our trucks or a one-off custom?
Gaylords Lids in California made it. They don't stock them. They are only made to order. If you decide to order one from them, talk to them about the upgraded hinges at the front. They didn't tell me about them until I had the cover installed and then saw the other style hinges at a show. I think that the upgraded hinges would be worth the difference in cost.
Kevin
Posted: September 18, 2011, 9:59 pm
by kstones63
I am making some progress on the engine swap. I am getting really close to sending out to the engine rebuilder.
I found someone that makes a wiring harness to convert the coil packs over to coil on plug design. This will clean it up a lot more.
I had to get a different set of valve covers to accept the COP and then find a set of coils.
This makes it so much cleaner without any spark plug wires to try and hide.
I think that I have the wiring all shortened and lengthened where it needs to be. I have all the wires wrapped and will need to be secured once the engine comes back.
This is what I decided on for the the MAF and the air filter. This pic still has the original coil packs that have now been deleted.
Kevin
Posted: September 18, 2011, 10:06 pm
by BackyardRest
kstones63 wrote:I am making some progress on the engine swap. I am getting really close to sending out to the engine rebuilder.
Kevin
Kevin, DId you decide which rebuilder is doing the engine?
Posted: September 18, 2011, 10:27 pm
by kstones63
No, I haven't decided yet. The guy that you referred me to wanted almost $6,000 to rebuild this engine so I think that he is out. If I was wanting to build a strong performance engine, that would be a consideration, but I am just looking for a rebuild back to stock specs. I probably will never get 50,000 miles on this truck so I am not worried about factory specs. I am talking to the shop that rebuilt the engine that is in there now but I am considering doing an engine swap with mine as a core but that is scary.
Kevin
Posted: September 20, 2011, 9:39 am
by BackyardRest
kstones63 wrote:No, I haven't decided yet. The guy that you referred me to wanted almost $6,000 to rebuild this engine so I think that he is out. If I was wanting to build a strong performance engine, that would be a consideration, but I am just looking for a rebuild back to stock specs. I probably will never get 50,000 miles on this truck so I am not worried about factory specs. I am talking to the shop that rebuilt the engine that is in there now but I am considering doing an engine swap with mine as a core but that is scary.
Kevin
That is a LOT of $$. You can buy the new Coyote 5.0 for 6995.00
Those engines should be pretty easy to find cheap and ready to go.
Did you ask Brian about a "stock" rebuild?
Posted: September 20, 2011, 9:48 am
by BackyardRest
Kevin
there are a few Lincoln Aviator DOHC's in town for under 2k. Think they were 300hp stock.
GT500 BLower motor or a bunch of other DOHC's avail cheap. Found 2 GT500 engines local. If you want a stock rebuild of your engine that can be done very reasonable too. Have a friend in town that owns a engine reman facility.
Also found a brand new Raptor with 1000 miles on it and 3500.00 asking for engine. A lot of options for a Ford Modular in town.
Posted: September 20, 2011, 10:07 am
by BackyardRest
I have seriously thought of dropping a 3.5L Eco-Boost in one of my trucks.
Found 3 of them for 5k each and all under 200 miles.
Posted: September 20, 2011, 10:11 am
by Gritsngumbo
BackyardResto wrote:A lot of options for a Ford Modular in town.
What town would that be? Or at least part of the country?
Posted: September 20, 2011, 6:20 pm
by kstones63
I am into this engine for absolutely nothing at this point. I parted out the Mark VIII and even made some money on it, so at this point the price of a rebuild doesn't scare me. I am planning on just having this one rebuilt to stock specs so that it will never have to come out of the truck again. It has 280 HP from the factory but I am guessing that with a free flowing air intake, no cats, dual exhaust and adding a chip to the EEC, it will be around the 320 HP area.????
The shop that did my other engine quoted me around $2200.
I have so much time in making the wiring harness, I don't even want to think about changing to a different engine that I would need to start over with.
Who is the engine reman that you know? I would like to talk to them.
Grits, That is the Phoenix area. He now lives back in AZ.
Kevin
Posted: September 20, 2011, 7:57 pm
by Bill W
Phoenix area Grits :)
Posted: September 20, 2011, 8:25 pm
by Gritsngumbo
Thanks guys. Just wondering where all those good bargains are. Don't find deals like those in our part of the country.
Engine
Posted: September 20, 2011, 8:42 pm
by bluebolt
Gritsngumbo wrote:Thanks guys. Just wondering where all those good bargains are. Don't find deals like those in our part of the country.
They are around here Grits just need to have cash on hand when they come up. Aviator engines in area are about 2 grand and there's a new f150 5.0 for 3 grand in Eunice LA.
Re: Engine
Posted: September 20, 2011, 8:44 pm
by Gritsngumbo
So that's the catch :-)
Posted: October 18, 2011, 10:10 pm
by kstones63
Well it appears that I am getting serious about getting this engine swap done. I got a rebuilt engine and used mine as a core. The specs came that it is still a standard bore and standard crank. I think that is a good thing. I put a rebuilt p/s pump on it, new idler pulleys and will install a new a/c compressor.
I painted the intake and got it installed.
I couldn't find any headers less than $750 to fit so I decided on stock exhaust manifolds from a Mustang Mach 1. They won't hardly be seen and they were cheap by comparison.
I had the transmission rebuilt and have it attached to the engine ready to go in.
I hope that by doing all the rebuilt parts that I won't have to ever pull the trans or engine again.
Kevin
Posted: October 20, 2011, 12:08 pm
by 64Ranger
Looks really good Kevin... should be a very reliable truck.
Keep up the good work!!
Posted: October 21, 2011, 11:01 am
by HiBoy63
Installing engine and trans is the way to go. Ive alway done them separatley. Ive been worried about the weight of trans and big block together but it went well. Next time I will double chain like what you have done. Looking good.
