57 I6 tranny ??
champion speed
57 I6 tranny ??
My 58 f100 with 292/3 speed has a nasty lower end noise...being bucks down I'd like to use a 57 Inline 6 (already have it). Question is will the v8 tranny bolt up to the 6?? Flywheel?? Thanks guys.
championspeed.net
- ezernut9mm
i think they are the same, but i don't know for sure.
the 292 v-8 and the 223 six have different patterns for the bell housings...
- ezernut9mm
well now, that's not very convenient. lol
yea....and guess what...nobody told me ! LOL
i put the motor in by myself....i bet i was under the truck & up above about 25 times before i relized it....
talk about frustration
luckily ,i had both bell housings and just swapped the one for the 6 to my tranny...
fmartin_gila
Now I am trying to come up with this all out of memory, which stands a good chance of being rather poorly due to my being older than dirt, but as I recall the bellhousings for the V8 and the I6 were different in that the two top holes where it mounts to the engine block were about an inch closer together on the I6 than on the V8. I think the 4spd and the 3spd mounting on the backside of the bellhousing was different. I think as long as both of the trans that you have, both being 3spd with the large input shaft, they should both have the narrow mounting pattern and should interchange. One caveat though is there may be some difference in length of the input shaft if one of them happens to come from a car as I seem to remember that there was a difference but don't remember which was longer or shorter or even if it was these particular transmissions.
Fred
Fred
- bobenhotep
my 63 has a 223 and the trans has a 1 3/8 input that is about 7 and a half inches long. i was told it was a big block tranny...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
