black powdery smoke from exhaust
Mr. D
Post by Mr. D »
Well when I pull the 66 352 into the garage it leaves a black film on the side of the house. So to keep everything good on the homefront I have been covering the left side of the dual exhaust with a pringles can to keep the black soot of the house.
Tonight I used a white rag and just the 60-120 seconds to pull it into the garage the rag was covered in blak soot.
Any ideas on what I can do to help "Ol Blu" run better.
Thanks Kelly :shock:
keep the rubber side down
Johnny Canuck
Post by Johnny Canuck »
She's a runnin' rich.
sounds like at low or idle speed -so first you can try turning the idle mixture screw down. On a holley carb it is on the drivers side and you have the truck running, turn it in until the truck stalls at idle, then turn it back out roughly 1 1/2 turns. Adjust to taste.
Best o'
JC
It's a race.. Will hell freeze over or will JC finish his truck first. Stay tuned..
jimbob1021
Post by jimbob1021 »
if you are useing a holley carb . and what i know about them you could have a bad power valve this will make the engine run rich and you will get black smoke coming out of the tail pipe .jim :idea:
Slick Fan
Re: black powdery smoke from exhaust
Post by Slick Fan »
Mr. D wrote:So to keep everything good on the homefront I have been covering the left side of the dual exhaust with a pringles can to keep the black soot of the house.
Now THAT's funny! :lol:
BTW, I'm not laughing at you, just laughing at the lengths we go to sometimes to keep peace on the homefront! :lol:
Oh & yes, it's definitely running rich. :wink: If it does it moreso when the engine's cold, having the choke closed will do that too.
My "Slickitis" affliction began here...
66 F100 CC/65 F100 CC/66 F250 CC
If it starts to rain, they'll tax the splash.
If you want to fish, they'll tax the bass.
If you plant a yard, they'll tax the grass.
If you don't play nice, they'll fine your *$#!
Mr. D
yep funny things I do
Post by Mr. D »
Yes it is funny my neighbor said "what are you doing" I said keeping the property values up in the neighboorhood.
Well I still have the stock "autolite" type carb on "Ol Blu", so later today I will pull of the air cleaner and start messing with the idle mixture screw and listen to what happens. :D
I tried to insert an Emoticon at the start of my text, but it kees poping to the end????
Slick Fan
Re: yep funny things I do
Post by Slick Fan »
Sounds like you're on Firefox? My Firefox does that & it disturbs me. :?
You can move your cursor back to where you really wanted it & manually type it in, just make sure you leave a space on either side, so it doesn't try to tie it in with a word.
Like this...
Code: Select all
word :D word
Hope that helps. :)
