R.I.P. my little slicks
Mr. Jones
Post by Mr. Jones »
Somewhere in the Ozarks......
___________________________________
"DW JONES TRUCKING"
WHISKEY HAULED,LIES TOLD AND WIDOWS WOO'ED......
"By appointment only"
Re: R.I.P. my little slicks
Still a huge amount of good parts there
Mr. Jones
Post by Mr. Jones »
This guy keeps all his old stuff,all the imports get crushed.......going back in the morning for a set of nice fenders and a couple of 16",8hole lock ring wheels for Farmmotorsports.....
"DW JONES TRUCKING"
Dan , keep an eye out for a 6 bolt rim for a f350
Be nice to find one for a single wheel truck
But I can run one built for a dually
Mr. Jones
Post by Mr. Jones »
I have a couple that can not be run on rear because of the off set,might be front only 6 hole 16” look jus just like a Dually with the six slots
"DW JONES TRUCKING"
rwhistles
Post by rwhistles »
what size you need? I may still have some 17s that came on my truck.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
7.50-17 is what I have on
I'm wanting to keep it the same if possible
I have a 16" that will work , but the offset is different
I can run it in the back axle , but not front
I'd like to have one that is the same
Your 17" sounds like it might be
rwhistles
Post by rwhistles »
will check this weekend and see if I still have them.
Dan the next time you go to your honey hole see if you can find a good front bed panel for a wrongbed
64x19 and how much. I could probably be persuaded to come out there for a good 9ft wrongbed.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
rwhistles
Post by rwhistles »
Pat. PM sent
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
aj64f100390-292
Post by aj64f100390-292 »
Mr. Jones wrote:This guy keeps all his old stuff,all the imports get crushed.......going back in the morning for a set of nice fenders and a couple of 16",8hole lock ring wheels for Farmmotorsports.....
I live 45 minutes from Springfield, mo where is this exactly? My 64 needs a drivers fender, door panel trim and mechanical door odd and ends.
1964 f100 lwb 292 ECG Heads,4v, 4spd, '76 9" 3.25, orig. :292 3spdO/D, 3.92 spicer locker
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
was FE/FT, mount:390, C6R heads, C4ae int, w/ 361/391 FT Bellhous.,timing cover, & w. pump.
-Back on the road since jan '17
