Speedway Disc Conversion
mac
Post by mac »
I've been looking but can't find what an answer. Has anyone that's done the speedway disc brake kit tell me if the stock wheels and innie hub caps work with the rotors they supply? I like the look of the bottle caps and would hate to give them up. Thanks in advance.
64 f100 shortbox 292 3spd
Re: Speedway Disc Conversion
Post by SteveCanup »
I installed the Speedway kit on my '64 F-100 with stock 15x7 steelies. They were wheels from a newer Ford pick-up. No clearance problems. The stock original 15x5 wheels might be an issue. I will say that the brake conversion kit is excellent and the price can't be beat.
1964 F-100
slixtyfive
Post by slixtyfive »
typically the early stock ford wheels won't work with disk brakes due to the profile of the back side of the wheel interfering with the caliper. But as noted above, the later stock steel wheels ('73 and later) were designed for the caliper clearance and look essentially the same from the side when mounted on the hubs.
"It's better to be gone but not forgotten, than to be forgotten but not gone." Gary Allan
mac
Post by mac »
So would spacers solve it? I want to keep my bottle caps.
aj64f100390-292
Post by aj64f100390-292 »
mac wrote:So would spacers solve it? I want to keep my bottle caps.
you might look into aftermarket steelies, I've seen some used with 66 and later caps so I'm sure it coud be done they added the clips by riviting them. I may do the same to my 64 as a set of winter wheels
1964 f100 lwb 292 ECG Heads,4v, 4spd, '76 9" 3.25, orig. :292 3spdO/D, 3.92 spicer locker
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
was FE/FT, mount:390, C6R heads, C4ae int, w/ 361/391 FT Bellhous.,timing cover, & w. pump.
-Back on the road since jan '17
charliemccraney
Post by charliemccraney »
A 15 x 6 wheel I have, which does work with discs, is 14 1/2" diameter where the caliper would be. That measurement is taken about 1" from where the wheel contacts the hub and remains about the same to the outside of the wheel. Within that 1", it does taper smaller. Compare this to your wheel and you should get some idea.
Truckrat
Post by Truckrat »
Mac, it has been my experience the drum brake wheels
Won’t clear the calipers on the disc brake conversions! Now,
Some 1/4” wheel spacers might be the answer to get clearance
enough between the wheel and caliper to do it! You could try
stacking some flat washers on your lug studs up to 1/4” and then
put the old innie wheel back on. Snug up the lug nuts and try to
spin the wheel and check clearance. If you have clearance then
you can run 1/4” wheel spacers. I just suggested the flat washers
to save buying the spacers if it doesn’t work! Wheel Vintiques has
Innie style wheels and caps so if you want a little wider than stock
wheel with an innie cap check with Summit or Speedway!
