Installing sway bar 66 f100 front
tomrooster
After market sway bar that I removed from another truck and it was mounted on each axle with angle bolted thru the axle about 3" closer to center from where the wishbone ? bolts to axle then bolted on frame in front of cross member and it was linked together with long bolts and rubber mounting hardware . Does this sound right? Thanks Tom
1966 F250 Camper Special parts truck
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
I'm still not a good welder but I've become a good grinder
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
Re: Installing sway bar 66 f100 front
Wish I could help you with this one as I've got a brand new Hellwig sway bar and I hope to install it when it cools off (i'm in AZ desert). Best of luck getting some advice out there and if you do I hope you don't mind sharing it with me.
tomrooster
Brute, found it, just like I was asking , drill a hole in front axle and them mount there and on bottom of frame . here's instructions. Tom
http://www.jegs.com/i/ADDCO/020/113/100 ... ProductId=
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
- 6166 Junkyard Dog
Personally I would get a original Ford Set up for sway bars, the 73/79 trucks had 2,, 73/74 you had to use the radius arms as well to complete it, 75/79 it just had a bracket that unbolted off the radius arms
Tom,
Lazy FORD Ranch
Dakota,,, RIP will never be the same looking for 61-66 trucks again ,,
Kathy
Slickstock,,, York, PA
Slickstock,,, Kansas City, MO
Slickstock,,, Altoona, IOWA
Slickstock,,, Salina, KS
Now Cooper will try his best
Cooper now has 2018 Slick Stock,, give him a fair star
Slickstock Kansas City, Mo
Lazy FORD Ranch
thanks for the directions Tom, had no idea they were on a supplier's website. I've got Dream Beams on mine, but I'll figure it out.
- Blackwaterforge
X26166 Junkyard Dog wrote:Personally I would get a original Ford Set up for sway bars, the 73/79 trucks had 2,, 73/74 you had to use the radius arms as well to complete it, 75/79 it just had a bracket that unbolted off the radius arms
I used my original forged radius arms rather than the latter stamped ones.
I just had to grinding a notch for the sway bar brackets.
If it cain't be fixed with a sledge hammer it must be an electrical problem!
