Hello all!
I was wondering does anybody have a picture of the fuse box / panel of a 64 f100?
I'm trying to connect a tachometer and don't know where to connect it to.
Thanks
64 f100 fuse box/ fuse panel
Re: 64 f100 fuse box/ fuse panel
To be frank, the fuse box on the 64 is connected directly to the light switch if I remember right. However to answer your question I think the owners manual has a picture in it with directions. If, that doesn't work for you, then I believe the back of the ignition switch has a hot connection for everything on the very farthes back nut of the back side. Just install a fuse in line and you are good to go. Messing with the fuse block is a real pain. From years of heat and detioration, I would not mess with it any more than I had to.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
