Thanks Ive got some other doors to install. Ill be welding up all the holes and doing some body work this spring. Plan is to get a HVLP paint set up and either get some flat black epoxy prime on it with a white top or do a satin black paint with a white top and that should hold it until its time for a complete resto in a year or two.totten wrote:Great build up. Cant wait to see in paint.
65 F100 4x4 parts truck turns project
Re: 65 F100 4x4 parts truck turns project
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
In case you are wondering thats Ireland......Freedom is not Free!!!!!!!!
Heritage country Flag
1965 F100 4x4x352
1998 F150 4x4x4.6
Got the rear bumper hammered out as good as it will be for now and sitting in primer ready for paint.
DSCN5031 by HiBoy63-65, on Flickr
Bumper brackets por15d and ready for paint
DSCN5025 by HiBoy63-65, on Flickr
Brackets will be a satin black and the bumper will be a silver color next pix will be of painted and installed.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Rear bumper with rattle can silver paint. I might go back to white it hides alot of sins. It will be a good 20ft bumper. Man that thing looks like a $5 bumper. Oh well repop in the future if I cant find a better chrome one.
DSCN5091 by HiBoy63-65, on Flickr
Lined it up on the back of the truck it should fit pretty good. Just waiting for the paint to dry on the mounting brackets.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Bumper installed
DSCN5102 by HiBoy63-65, on Flickr
It looks like a $5 bumper. It doesnt look like I did much to it. Hey that bumper metal is hard to pound out.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
looks a little better in day light. I think Ill re paint it in a flat white color it will probably hide the dents and dings that I couldnt pound out.
DSCN5112 by HiBoy63-65, on Flickr
DSCN5111 by HiBoy63-65, on Flickr
Not to bad from 20ft and in pics. The flat white paint should hide the abuse a little better. I hope.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
I kinda like a little rough around the edges. Looks great
wow, my bumper looks totally different.. guess it was added at the dealership, weird that I didn't realize ha
Yes that is the stock factory bumper that would have come with this styleside bed. Just so you know the bumper brackets used on the flairside box will work with this bumper on the older styleside bed. You have to drill a new hole for the front bolt but other wise they are the same. In the aftermarket cats that I have looked at I dont think they say those brackets will fit this bumper it could be because you have to redrill for the front hole on the frame. And price wise they sure are proud of these brackets.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Started welding up the chrome holes and all previous holes in the doors and box by previous owners.
Ill be posting more of these as I go. Im finding these are not the easiest holes to repair and weld in.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Hiboy,
I used nails when I filled mine in. Just used a nail head with slightly small diameter then hole, tack it in an then fill in. Nail shaft gives you something to hang onto when tacking and then grinds off easy enough.
Looking good.
Ken
Looking good.
Ken
I might give that a try on the doors if I cant figure out a way to get a piece of copper to stay behind the hole or the brass punch. Thanks for that tip Ken.
Finished the passanger side of the hood and did a hole in the front lip of the hood from a bug deflector screw that had rubbed a hole in the front of the hood. Moved around to the drivers side and started filling on that side.
Next I will be doing the passanger door with all the various holes that have been put there by the previous ownders of the truck these doors came off of.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Inside of the doors have holes that you can run a bolt thru...double nut it and you can turn the bolt to press against a 2x4 or other suitable scrap lumber to press against the copper, holding it in place. I used copper pipe, cut down the center and flatten...it will bend easily to the contour of the doors if needed.
Great idea Ken. That sounds like it would work really well. Maybe even a piece of angle iron or square tubing. Sounds like a plan thanks for that.ken462 wrote:Inside of the doors have holes that you can run a bolt thru...double nut it and you can turn the bolt to press against a 2x4 or other suitable scrap lumber to press against the copper, holding it in place. I used copper pipe, cut down the center and flatten...it will bend easily to the contour of the doors if needed.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
I got the holes on the hood finished up with the copper behind the holes. Finished the door by pulling nails thru from the inside and holding the head up against the hole to tack the nail in place. Once nail was tacked in I cut the nail shaft off and welded the hole closed. It will probably need a little filler as the heat from welding the hole close caused the metal to pucker in to a low spot around the weld. That was with a cold wet rag trying to stop that. If I could get to that area with a hammer I could bring those puckers out and grind smooth with no filler.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
Some more work welding up chrome trim holes and rear view mirror holes. Also worked some of the dents out of the passanger side front fender and started doing away with the hole in the side of the bed where someone had mounted some kind of antenna. Im suspecting probably from the CB radio days.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
More welding and pounding.
I didnt quite get done with the crease I had to go and I need to take the wheel off to finish it up so primed it and will come back to it next time.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
I used a slap dolly or hammer on and off dolly to finish the crease out. With this method I was able to get most of it out but unfortunately when the metal was creased it stretched it to. I come back to it later with and english wheel to try and shrink it back a little. In the night pic I can see where the bed floor and wheel well attach to the outer wall in all the spot welds appear to be puckering in so a coat of filler over those for now.
Its still to cold outside here to start with the filler.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
looking good
More banging, cutting, pulling, and welding.
I was able to get some of the crease out but what is left is hiding right at bed level and behind the brace for the bed floor the 2 upper dents are right at the seem were the back tailight panel is spot welded inside the bed so no getting to them till that tailight panel comes off in a few years.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
1965 F100 4x4x352
1998 F150 4x4x4.6
liking watching your progress on the bodywork. looking good.
