wiring blinkers
blueovalmadness
wiring blinkers
Does anyone know what wires on a 78 column I need to plug into the connectors under the dash of a 65 for the blinker switch?
THIS HERE IS THE GREAT STATE OF IOWA THE LAND OF RUST
64 f100 short box 302 auto
56 customline 2dr post cobra jet auto
79 trans am 455 auto
93 f350 4x4 cclb the dirty diesel
92 f250 36s 460 auto
78 f250 4x4 400 4 gear now sporting a 65 f100 custom cab body
Re: wiring blinkers
The 78 and 65 should have the same color for the wires. You will not use the wires for the column mounted hazard switch.
Over the hill and picking up speed!
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
2012 Dodge Caliber (Hers-under protest)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
Spend the summer as Meatloafs Roadie
Be a member of the "Five Timers" club
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
blueovalmadness
Re: wiring blinkers
They aren't the same colors
- charliemccraney
Re: wiring blinkers
This is for the '73-'77 switch, with integrated hazards and manual transmission.
Do these colors work?
And this is how I believe it will be wired into a '61 harness. Most of the colors are the same in this case.
The best thing you can do is to get a 78 wire diagram and a '65 diagram to translate the diagrams from one to the other.
blueovalmadness
Re: wiring blinkers
Thanks guys I got it figured out and am now finally driving it to work
