broken bolts, water inlet
Got a helpful tip or trick related to your slick? Please share...
twall64
Post by twall64 »
last night I was going to remove the aluminum water inlet from the intake manifold so I could drill and tap for a 1/2 inch NPT fitting for a temp probe. I was proud of myself for getting everything together before starting the job like a new thermostat, gasket, sealer, drill and tap and expected to be finished and at home for the debate on TV. Using a short handle ratchet I tried to ease off the bolts and with very little force the first one twisted off, then the second one as well. I tapped on the housing with a hammer to loosen it and removed it without problems then cleaned the area around them. I got some 3/8 nuts and placed them over what was left of the bolts and welded them together. I gave them a minute for the heat to move into the manifold and put a socket on them and they came out with little effort. I had also used this method before on the front of the engine when I had to remove the timing cover and it worked flawlessly.ImageImageImageImageImage
MadMaxetc
Re: broken bolts, water inlet
Post by MadMaxetc »
The heat from welding will help break the rust bond, so don'
t just tack the nut on. Turn up the heat and let her fly!
My Build Thread
then of course you used anti seize on the new bolts so this would not happen again
i hope.
Alan Mclennan
Australia
Post by Alan Mclennan »
OK! I`ll say it!........Nice work Twall!! :thumright:
Slick Stock 3 KCMO
Slick Stock 4 Altoona
Slick Stock 5 KCMO
Slick Stock 6 Altoona
Slick Stock 7 Salina KS
twall64
Post by twall64 »
I think the previous owner used low grade bolts. They did not snap when they broke they just twisted around and broke.
bird55
Post by bird55 »
good job!
my situation is always a bolt upside down and in some place I can't get into or something. And I don't own a welder either!. And it seems like they break off flush. Never much fun. Ever.
olliesshop
Post by olliesshop »
Nice trick ...
Tim - 1961 F250 Uni
"Big Red" pictures ... http://olliesshop.smugmug.com/Trucks
Current build thread ... viewtopic.php?f=32&t=29505
