65 f100 upgrades round II
Re: 65 f100 upgrades round II
flip the rear and put the drop spindles back on
Definitely lower the rear some more. My rear fenders cover about 2 inches of a 17" wheel and a 275 rear tire. The only problem with that is if you have to change a tire on the road, I will need to raise the tires off of the ground and then use a bottle jack to get the frame high enough to let the tire clear the fender and then it will barely come off.
Your truck looks great.
Kevin
Kevin
kstones63
_______________________________________
63 F100
29 Ford Sedan Delivery
99 F250 PSD, 4x4, CC
95 F350 Flatbed Dually Diesel
63 F100
I ordered a new hanger that should give me 1.2" more in the rear. If it's not enough I can flip the original hanger. Because I have the lowering spring I don't think flipping the axle is an option. It would put the housing into the bed. I should get it done this weekend. I did get it out on Sunday and cruised for a couple of hours. It hasn't been on the road since 2007 so it was very satisfying.
Kevin, you gonna make it to KC SS. i'd love to see your slick in person. Amaizing work.
65 f100 SWB
51 F1
52 F3
51 F1
52 F3
I plan to be there as of right now.
Hopefully nothing will get in the way.
Kevin
Kevin
kstones63
63 F100
63 F100
stoney1964
Always lower never raise!
Looks great! I lowered mine 14 inches from original height. I flipped my rear end and pulled a couple of spring leafs, perfect now. Barney Fife always said Rule # 1 is to obey the rules, Rule #2 is lower it, Rule # 3 see Rule# 1
Got the old hanger off, went to bolt the new one on and not close. You can see in the pics below. I don't think they sent the correct ones. Anyway welded up the holes and made new. Here is how it sits now. Had some time to do a couple of other thing too. Put the passenger mirror on, put the golve box in, and got the heater working again. Gonna get it aligned while I am out of town this week. Still have to notch the rear so I had to be careful driving down the road, only about 2" travel.
keith
keith
- IMG_0488.jpg (70.55 KiB) Viewed 2190 times
- IMG_0486.jpg (73.34 KiB) Viewed 2190 times
- IMG_0485.jpg (41.14 KiB) Viewed 2190 times
65 f100 SWB
51 F1
52 F3
51 F1
52 F3
rickairmedic
Much better
now put the lowered spindles back in to give her just a little rake
:D.
if it aint broke fix it till it is
Looks awesome, those wheels really set it off as well. Id say you've got the ride height perfect now....
VERY jealous!
Love the stance two thumbs up
2010 Ford Edge
99 Ford Expedition
65 Ford f-100 swb
460 stock other than a double roller timing chain and a s475 TURBO pushing 6psi of boost (now 12lbs)
351 W Pulled and on garage floor in storage
428 4v (R.I.P)
c-6 wide ratio modified
torino front stub
home made ladder bar rear with air bags
11.96 sec @ 110mph 1\4mile (best with the 428)
99 Ford Expedition
65 Ford f-100 swb
428 4v (R.I.P)
torino front stub
- Alan Mclennan
Looking pretty sharp Keith, I like the stance!
Slick Stock 3 KCMO
Slick Stock 4 Altoona
Slick Stock 5 KCMO
Slick Stock 6 Altoona
Slick Stock 7 Salina KS
Slick Stock 8..............................
Slick Stock 3 KCMO
Slick Stock 5 KCMO
fire truck
Lookin good dude!
So good lookin' that I've attracted an international stalker.
Rest in Peace Bumpstick....I miss ya man.
Now you have it looking good.
Kevin
Kevin
kstones63
63 F100
63 F100
very nice build...Thats exactly what I want in my 65....a HO 302 EFI with T-5 out of a mustang, nice wheels, and a good stance...with front disc brakes
you have done an excellent job...keep up the pics...we love em!
1965 SWB 460 C6 AUTO "Red Barron Red"
1965 SWB Going 302 w/C4 Auto (Matthew's)
1969 Dodge Charger "replica General Lee" 440 w/727 (Mine)
If you sent your Truck out to a restoration shop, you did NOT build it, jus sayin!
Been a daily driver for the past month and a half now. 20 mpg is better than my 07. I did c-notch the frame last weekend and picked up some shim to adjust the pinion angle, off 2 deg and there is a slight vibration around 50 but this should take care of it. Here are some pics of a project I have been working of the past few weeks. Swaped out the 289 for a 358 hp 302 from ATK with a fast ez efi and a 5 speed. I did this for a guy at work. Funny thing is about half way through he got promoted and is now my boss. Kissing up to the new boss and didn't even know it. Anyway, been looking into air conditioning as it is getting hot. Any suggestions.
- 1.JPG (40.96 KiB) Viewed 2045 times
65 f100 SWB
51 F1
52 F3
51 F1
52 F3
Man you have done a great job I wish I could get my 65 that low with out the camber on the front
Been awhile since I have updated. I ended up building another motor since the mustang donor had significant mileage on it. Found a ford racing crate on CL with 20,000 miles on it. Pulled it apart and freshened it up with gaskets. Its a 306ci SVO aluminum GT 40X heads, 1.6 RR, trick flow intake 76 mm tb, 24 lb injectors and MAF Here are some pics. Also found a recovered seat from a 92 which I will have to take some pics. Also got an Anderson motorsport tuner and vortech supercharger coming with around 10lb of boost. Should put me around 375hp to the wheels. Anyway here are a few pics. Enjoy. Sorry I miss SS, was picking corn. Bad thing was I am only 300 miles away.
- IMG_0600.jpg (103.41 KiB) Viewed 1944 times
- IMG_0597.jpg (84.12 KiB) Viewed 1944 times
65 f100 SWB
51 F1
52 F3
51 F1
52 F3
